Toymods » Tech & Conversions » ga70 overboosting?
2Lsupra
ga70 overboosting? Mon, 24 November 2003 02:13 Go to next message
hey just need sum help with my ga70,
It runs fine on about 10psi but as soon as wind it up anymore it just hits a "flat spot" of some sort. not sure what you call it but just feels really flat, overboosting or something? is it fuel starvation? would a fuel cut defender rectify this? i jsut thought its a bit weird since i have read plenty of you guys running up to 14 pound everyday...? only mods i have are 3 inch catback, pod filter and GFB mechanical boost controller if that helps.
thanx for any advice guys
Danners
Central Coast, NSW
Re: ga70 overboosting? Mon, 24 November 2003 02:19 Go to previous messageGo to next message
You need a fuel cut defender my friend!
Dan
[Updated on: Mon, 24 November 2003 02:19]
2Lsupra
Re: ga70 overboosting? Mon, 24 November 2003 02:32 Go to previous messageGo to next message
oh ok i thought that may be the problem. so if i do put one in i proly wouldn't wanna wind it up much past 14psi anyway would i? considering it's a stock 1g-gte...
Danners
Central Coast, NSW
Re: ga70 overboosting? Mon, 24 November 2003 02:41 Go to previous messageGo to next message
I don't know much about 1G's but i beleive they use the same turbo as the 1J (CT-12??)
I wouldn't be running a stock turbo any higher than 13 or 14 myself without asking for trouble... I would be doing some internal strengthening as well Very Happy
Dan
Re: ga70 overboosting? Mon, 24 November 2003 02:47 Go to previous messageGo to next message
1G's have CT12's which are quite different to the CT12A's found on a 1JZ, and they don't flow anywhere near as much. 13-14psi is probably the upper limit for the turbos, but the engine itself can take heaps more than that without internal strengthening. Like most Toyota engines, the 1G is quite over-engineered.
2Lsupra
Re: ga70 overboosting? Mon, 24 November 2003 08:10 Go to previous messageGo to next message
yes norbie you seem to know quite a bit, so can you tell me if a fuel cut defender would help my problem and if so are they fairly straight forward to install myself? should only set me back 200 buks or so? do all you other guys with 1g's have fuel cut defenders?
Re: ga70 overboosting? Mon, 24 November 2003 08:16 Go to previous messageGo to next message
Yeah a FCD should solve your problems. If it's anything like the FCD I installed on my 2JZ, it should be a piece of piss to install. All you really need is the pinouts for your ECU so you can identify the correct wires, and the ability to solder wires together. Easy stuff.
2Lsupra
Re: ga70 overboosting? Mon, 24 November 2003 08:19 Go to previous messageGo to next message
all right i give it a try thanx man
Dabbid
Yowie Bay, Sydney
Re: ga70 overboosting? Mon, 24 November 2003 10:19 Go to previous messageGo to next message
i was running 15psi on mine without an FCD
i'd check your AFM
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: ga70 overboosting? Tue, 25 November 2003 07:08 Go to previous messageGo to next message
Do you know what generation your 1G-GTE is?
2Lsupra
Re: ga70 overboosting? Tue, 25 November 2003 08:51 Go to previous messageGo to next message
nah i dont, because apprantly its a 86 supra, on the ID plates it has the engine as a 1g-gteu. now i thought that the "u" meant it was a water to air intercooled version, however it definantly has a air to air intercooler, whether or not that has been changed i dont know...? injector plugs are grey and its amanual if that helps?
STR8 2.8
Re: ga70 overboosting? Tue, 25 November 2003 10:07 Go to previous messageGo to next message
the 'u' means japo emissions stuff
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/EngineCodes.html
Nark
Cabramatta, NSW
icon1.gif  Re: ga70 overboosting? Tue, 25 November 2003 22:34 Go to previous messageGo to next message
2Lsupra wrote on Tue, 25 November 2003 19:51
I haven't seen grey injectors...
Check here for the different versions that we know about:
http://www.toymods.org.au/1g_versions.html
Bugman
Re: ga70 overboosting? Wed, 26 November 2003 00:18 Go to previous messageGo to next message
boost cut aint no flat spot.. it's more like the feeling of being thrown through your front windscreen!
2Lsupra
Re: ga70 overboosting? Wed, 26 November 2003 08:41 Go to previous messageGo to next message
ok i looked properly this time, and unfortunatly the injecter plugs are yellow,
so this a gen 1? the worst of em all?
Nark
Cabramatta, NSW
icon2.gif  Re: ga70 overboosting? Wed, 26 November 2003 22:42 Go to previous messageGo to next message
Yup. That was my feeling. That's why you're hitting boost cut when others haven't.
It's interesting that they converted to air to air though. Can't see the reasoning for that. This coming from someone who's converted a Gen 3 from air to air into water to air... Smile
2Lsupra
Re: ga70 overboosting? Thu, 27 November 2003 08:09 Go to previous messageGo to next message
yeh i not sure why it been converted either then.
so would a FCD solve my problems? seing as it a boost cut happening?
Nark
Cabramatta, NSW
Re: ga70 overboosting? Thu, 27 November 2003 22:33 Go to previous message
You would hope so! Smile
We don't know much about the Gen 1s so I don't know if their fuel cut is actually lower. Smile
Previous Topic:4AC Rpm Questions..
Next Topic:grinding noise
Current Time: Wed Oct 21 02:57:32 UTC 2026
Total time taken to generate the page: 0.0055451393127441 seconds
