Toymods » Tech & Conversions » Supra MA70 Front Suspension LCA Mounts
OP111
Supra MA70 Front Suspension LCA Mounts Mon, 24 November 2003 02:21 Go to next message
Has anyone had any experince of repairs on front suspension mounts on 86.5 MA70 Supra?
The mounts are the ones the bolt for the adjusting Lower Control Arm bushes attach to. The angled track that the LCA bolt adjusts along is worn and apparently needs a patch welded in to stop movement. If anyone has come across this, any helpful advice would be approciated.
OP
lumpy
Adelaide, SA
Re: Supra MA70 Front Suspension LCA Mounts Mon, 24 November 2003 02:53 Go to previous messageGo to next message
Are you talking about the eccentric shaped washer that allows adjustment for wheel alignments etc? If so you're better off replacing them with new ones from toyota.
If your lower control arm is worn then I'd suggest finding another one from a wreckers/importers etc, or seeing if you can get a new one from toyota. Welding of suspension parts is often frowned upon by Transport authorities.
OP111
Re: Supra MA70 Front Suspension LCA Mounts Mon, 24 November 2003 03:19 Go to previous messageGo to next message
The washer is worn and has to be replaced but far worse the track that the bolt runs in on the chassis has a worn section that means that the bolt can't be secured properly and eventually loosens off.
It's because the previous owner drove it with dead bushes. Mad
I'm sure the transport authorities reaction will be worse when I take a tangent of a corner because the camber/toe are completely screwed! Smile
OP
Allan
Re: Supra MA70 Front Suspension LCA Mounts Mon, 24 November 2003 03:22 Go to previous message
I may have a spare x-member if your not in a hurry let me know
Allan
Previous Topic:external wastegate/oxygen sensor effects?
Next Topic:3sgte corolla??
Current Time: Sat Nov 21 09:10:50 UTC 2026
Total time taken to generate the page: 0.0037479400634766 seconds
