Toymods » Tech & Conversions » For Those Who Have Done The 1jzgte Conversion
666supra
U.S.A
For Those Who Have Done The 1jzgte Conversion Fri, 26 July 2002 23:52 Go to next message
1. Do you guys replace the head gasket with a new one or just retorque it? If replace, what's the torque spec?
2. Do you take out the oil pan for inspection? If yes, is the old gasket reusable? If not, where can I get one?
3. Does the 2jzgte timing belt work on the 1jzgte? If not, where can I get one?
4. What else are there that may need to be checked and change?
deesonet
Toowoomba
Re: For Those Who Have Done The 1jzgte Conversion Sat, 27 July 2002 08:19 Go to previous messageGo to next message
We used a half-cut for our conversion.
We didn't replace the timing belt but should have. It is now almost impossible to do when fitted in the car.
As the 2JZ is almost 30mm taller I assume that the timing belts are different.
I had the sump off as I had to make a complete new unit. I used silicone type sealant instead of a gasket. It hasn't leaked so far in 6 months.
I guess we were lucky - our engine has been fine. There were no problems with it at all.
Grant
Newcastle, NSW, Australia
Re: For Those Who Have Done The 1jzgte Conversion Sat, 27 July 2002 14:02 Go to previous messageGo to next message
1J's do not suffer the same head gasket problems as the 7M engines. You do not need to touch the engine in this regard.
666supra
U.S.A
Re: For Those Who Have Done The 1jzgte Conversion Sun, 28 July 2002 04:33 Go to previous messageGo to next message
Have any of you guys/girls done a timing belt change? If yes, then where can I get one from?
What about the head torque? I'm going to do some heavy BOOSTING on mine and want to make sure the head is tighten down real good.
Re: For Those Who Have Done The 1jzgte Conversion Sun, 28 July 2002 07:08 Go to previous messageGo to next message
As mentioned by Grant, the JZ engines do not suffer from head gasket problems like the 7M's. Leave the head studs alone.
deesonet
Toowoomba
Re: For Those Who Have Done The 1jzgte Conversion Sun, 28 July 2002 09:25 Go to previous messageGo to next message
I took the head off our second 1JZ today. It was very difficult to undo the head studs. They must have been torqued up enormously or else they used loctite on them.
[Updated on: Sun, 28 July 2002 09:27]
trev64
Re: For Those Who Have Done The 1jzgte Conversion Sun, 28 July 2002 10:43 Go to previous messageGo to next message
Timing belt part # 13568-46010.
That is a genuine toyota timing belt.
Timing belt replacement is best done when the engine is out of the car. It gives you room to get a impact gun onto the crank bolt (trust you will need it!!!!).
Just finished a 1jz into 1986.5 MA70 so everything is still very fresh in my memory.
666supra
U.S.A
Re: For Those Who Have Done The 1jzgte Conversion Tue, 06 August 2002 21:56 Go to previous messageGo to next message
Where can I buy the 1jz-gte Timimg belt from? I called my local toyota dealer and give them the part number and they say they cant get it. So can you guys/gals name some place or sites where I can get them.
thanks.
HedgehogSandwich
UK
Re: For Those Who Have Done The 1jzgte Conversion Wed, 07 August 2002 12:46 Go to previous message
What do you mean by 'serious boosting'? You wont have a problem with the head ..period. At big boost you will have a problem with the turbos though.
adi
Previous Topic:3TGTEU pistons
Next Topic:18RG with electronic ignition into RA23
Current Time: Sat Oct 31 13:21:39 UTC 2026
Total time taken to generate the page: 0.030531167984009 seconds
