Toymods » Tech & Conversions » RA65 front discs on to RT142
Asher
Northgate, QLD
RA65 front discs on to RT142 Mon, 24 November 2003 07:08 Go to next message
I saw somebody post that RA65 front disc setup will fit straight onto an RT142.
Since I don't know much about cars,
If I was going to go to the wreckers, what are all the parts I would need to get?
rob_RA40
c'town, NSW
Re: RA65 front discs on to RT142 Mon, 24 November 2003 07:31 Go to previous messageGo to next message
nevermind
[Updated on: Mon, 24 November 2003 08:05]
Re: RA65 front discs on to RT142 Mon, 24 November 2003 07:56 Go to previous messageGo to next message
Are they ventilated though?
rob_RA40
c'town, NSW
Re: RA65 front discs on to RT142 Mon, 24 November 2003 08:05 Go to previous messageGo to next message
my bad disregard my post
Re: RA65 front discs on to RT142 Mon, 24 November 2003 08:19 Go to previous messageGo to next message
OK then. Smile
To answer the original question, you want the hub/rotor assembly and the calipers from an SA63 or RA65 Celica. While you're at it grab a set of new wheel bearings from Repco or whatever.
A friend of mine did exactly this on his ST141 Corona and it was literally a bolt-on job. I assume an RT142 would be the same.
Asher
Northgate, QLD
Re: RA65 front discs on to RT142 Mon, 24 November 2003 10:21 Go to previous messageGo to next message
cheers norbie,
maybe this could go on the tech page?
Asher
Northgate, QLD
Re: RA65 front discs on to RT142 Mon, 24 November 2003 12:10 Go to previous messageGo to next message
hmmm, is there a difference between the RA65 and a RT142 Brake Master Cylinder?
And if it is...
Will I need the RA65 brake master cylinder for use with the larger disc brakes?
Re: RA65 front discs on to RT142 Mon, 24 November 2003 12:57 Go to previous message
I'm pretty sure the RA65 master cylinder has a 15/16" bore. Check your master cylinder, the bore size should be stamped on it somewhere. Note that it's relatively cheap and easy to get yours bored out to a larger size if necessary.
Previous Topic:4AC problem again
Next Topic:what is this?
Current Time: Sat Nov 21 08:38:15 UTC 2026
Total time taken to generate the page: 0.0050449371337891 seconds
