Toymods » Tech & Conversions » front pipe
2Lsupra
front pipe Mon, 24 November 2003 08:17 Go to next message
any one out there got some sort of figures for the power increase of fitting a larger front pipe straight off the turbos?
atm i jsut have a 3 inch cat-back on my 1g supra...would it be worth the cost? if so 3 inch or just 2.5 inch?
celicaboy_2000
Lismore, NSW
Re: front pipe Mon, 24 November 2003 09:21 Go to previous messageGo to next message
Bigger the better for turbo motors, i'd go with the 3" straight of the turbo's. I personally feel that mandrel bends aren't worth the gains for a 2litre motor but hey if you can afford it go 4 it. Thats my view anyway
Re: front pipe Mon, 24 November 2003 09:22 Go to previous messageGo to next message
Mandrel bends will cost fuck-all extra for a job like this. Generally they'll use pre-fabricated bends and weld them together, and this doesn't cost much to do.
Re: front pipe Mon, 24 November 2003 10:37 Go to previous messageGo to next message
Definitely use mandrel bends for your dump pipes. Your first metre of exhaust is so important, I wouldn't compromise it with press bent constrictions.
Re: front pipe Mon, 24 November 2003 11:02 Go to previous messageGo to next message
is there enough room in a 1G supra to let you have two separate dump pipes from the two turbos (instead of the factory cast thing that points the outlet gasses at each other!?)?
i vaguely recall seeing this done to 1J's but if the engine bay's anything like a celica RAxx with a 1G transplant, there's not enough room on the exhaust side to squeeze off a falafel-chillie-and-tabouli fart - let a lone have two dump pipes that side step around each other for the first 20-40cm.
charles.
Re: front pipe Mon, 24 November 2003 13:01 Go to previous messageGo to next message
Yes it's common with 1JZ's, but the turbos are too close together on a 1G to do the same thing. That said, you're going to hit the flow limit of the turbos long before the factory Y pipe becomes a restriction, so don't worry too much about it. Smile
Bugman
Re: front pipe Wed, 26 November 2003 00:07 Go to previous message
actually there was a guy on the forums that went to the trouble of making a custom manifold and seperate dump pipes. so that both turbos were facing forwards.. (still using the standard turbos)
apparently it worked quite well.
but if you ask me.. if your going to go to that much trouble wouldnt you use a different turbos?
Previous Topic:2T-G accelerator cable setup
Next Topic:1G-GTE Wiring Diagram
Current Time: Sat Oct 24 12:47:36 UTC 2026
Total time taken to generate the page: 0.0058271884918213 seconds
