Toymods » Tech & Conversions » St185 group A W to A intercooler questions
Classique71
Colac, Victoria
St185 group A W to A intercooler questions Tue, 25 November 2003 01:41 Go to next message
Hi guys .. Ive managed to track one of these setups complete from a dismantler - just need a few questions answered ..
For starters - how difficult is it to install into a stock st185 for those who have tried it and what boost limits can the intercooler handle ( im looking for around 20 PSI at the end of the rebuild )
Also regarding the intercooler water pump - is it better to have it on all the time while ignition is on - or have it temerature sensing to kick in at a certain level ?
My new ECu should be able to handle the Waterpump temp thing when it goes in as well ..
Also - is there any benifits ( bar a cheaper cost ) to getting one of these over a front mounted air to air setup ?
i know A decent front mount will cost me more than what the W to A is going to cost me - plus theres the addition of trying to get all the piping in around stuff whereas the w to a fits on where the other came off.
Ease of setup maybe? more boost ability? cooler charge ?
JustenGT4
Re: St185 group A W to A intercooler questions Tue, 25 November 2003 02:39 Go to previous messageGo to next message
There are two main benefits in this a/w setup over a/a for a street car. 1st off is the flow path is 5 times shorter so throttle response is better with the a/w. Second is the cooler works straight off the line and is effectively dumping heat while stationary.
At the end of the day though it all comes down to the hp you are looking for. The a/w will handle the heat generated by 19psi OK with the CT26 so a bigger more efficient compressor will be no probs at all. Once you start generating really big flow though i have found the intake charge passes thru the IC so quickly it doesn't get the chance to cool. This was with the much larger and better flowing 205 IC though so probably won't effect the 185 one as badly. I use an ERL WI kit to supplement the IC.
To fit tou will need the brackets as well as they are different on the non GrpA. Run the pump all the time, very noticeable benefits in cooling. Sheild the thing as best you can from heat sink in the engine bay. Wrap the sides and base with thermo tec adhesive tape and see if someone can make you up an alloy heat sheild to sit between the engine and IC.
A big well designed frontmount is the ultimate but the a/w is generally good enough and easily supplemented with WI if required.
spectral
Re: St185 group A W to A intercooler questions Tue, 25 November 2003 03:16 Go to previous messageGo to next message
What are peoples thoughts about rotating the compressor housing so the turbo outlet is pointing downwards?
Might reduce the pipework length required.. hence improve the response... and make it look less like an explosion in a plumbers shop.. ie : http://www.alltrac.net/images/intercooler/SupraFro ntIC2.jpg
Classique71
Colac, Victoria
Re: St185 group A W to A intercooler questions Tue, 25 November 2003 09:21 Go to previous messageGo to next message
Cheers justen - your a wealth of Gt4 info!
So - basically as long as the setup is complete - its a fairly easy swap to bolt in for street car use, will handle 17 - 20 PSi from say a Highflowed ct26 ( or garret setup like yours?) with no dramas , and work even better with a Water injection setup assisting it ?
Also shielding it will lower temps in the intercooler from heatsoak - so help it cool charge better?
I remeber being told that for example 16 PSI on a highflowed turbo is similar to a higher psi level on a standard turbo - so in theory should generate less heat at lower boost BUT still deliver the same amount of power or moreso ?Also i have found the group A bonnet this came off , and will be getting that too - so that ALSO should aid in lowering underbonnet temps further when i remove the silly grate thing that blocks the hole
In your oppinions - its worth investing in this in favour of a Air to Air setup ( priced somewhere in the vicinity of 1500 easy for a decent one installed )
I can buy the bonnet and the W to A setup for less then this AND have it installed and painted to match my car for the price if a really decent A/A intercooler seeing my car will never be a totally insane Gt4 - just a mildly scary one that looks sweet as ! Wink
sideshow
Re: St185 group A W to A intercooler questions Tue, 25 November 2003 11:33 Go to previous messageGo to next message
i have fitted a water toi air intercooler settup in a non water to air celica
nothin really bolts up straight forward
and i also think the outlet of intercooler to throttlebody
( a black plastic pipe with a sqaure on one end) this bolts to throttle body
this is bigger on the water to air so u might have to make sure u get it too
then u have to mount the pump
im pretty sure theres no straight forward mounting
and then u have to run the pipes a fukin shitfight
especially if u have a/c
this was just my experience on one model st182 or 185 celica
im much into what model has what but it was a gt4 type celica non water to air and we fitted a warter to air
we spent like close to 2 days fukin round with it so it would get expensive at a workshop
i also wired up the intercooler water pump to run 8 volts off boost then when u hit boost it would run 14 volts on a timer so each time u hit hi boost it would run 14volts for a minute
was big job and had to be done properly for a targa tasmania car
not to sure if u will run into same probs
[Updated on: Tue, 25 November 2003 11:40]
Classique71
Colac, Victoria
Re: St185 group A W to A intercooler questions Tue, 25 November 2003 11:55 Go to previous messageGo to next message
ok - so a reducer/adaptor would need to be made to fit the intercooler to the throttle body .. mine does have a smaller one than a group a - i think grp a is 55 mm - whereas mines 50 ..
Pipings always gunna be a shit - i know thats coming - and to mount the heat exchangr will rely on getting in under the bumperbar ..
Ill probably see about getting the ECU wired in to control the pump for constant flow when it goes in as well - otherwise ill runi it constant at a set voltage
Anyone able to get some detailed pictures on the mounting points etc of the unit for me - to work off ?
ie how the intercooler mounts - where the pump mounts , where the heat exhanger goes - and where the piping runs ...
JustenGT4
Re: St185 group A W to A intercooler questions Wed, 26 November 2003 02:26 Go to previous messageGo to next message
Like i said if you have the brackets the IC will bolt straight up. It'll line up with the turbo perfect and the throttle body but you'll need an adaptor for the trottle bod or get a GrpA one.
As for the pump and lines, you have all the bolt holes etc in place (the 184 does not) so it's just a matter of bolting it all up...should be easy if a little time consuming.
as for the eternal question a/a or a/w? there are endless debates about this everywhere on the web. I said that for a street car there are some adavntages but the ultimate is a big FMIC. I kept the a/w because i knew i could make it work well and it's in keeping with the GrpA...i didn't want to butcher a GrpA too much.
20psi would be pushing a 185 a/w but with WI no probs at all. And yes a bigger turbo *generally* is more efficient at a higher boost than a smaller factory turbo so for the same boost level there's greater air flow and less heat.
Classique71
Colac, Victoria
Re: St185 group A W to A intercooler questions Wed, 26 November 2003 07:11 Go to previous message
Cheers again justen - i owe you a coldie at dubbo Smile
as far as i was told this intercooler kit has EVERYTHING needed - its straight off a car that was parted for the motor and gearbox - so im hoping to hell it has all the brackets - if not -out comes mistwer angle grinder for my patented " classique 71 " customisation services..
Sounds like its got the thumbs up from all involved in answering my questions and should help with my goal of making a better group A Smile
As a side note i ordered the 3 inch HPC coated dump pipe and midpipe/cat today - should be hear early next week ! whee !
also toyota bites for the cost of gaskets for exhausts .. bastards! Oh well i have to win some and loose some to make my car happy
Previous Topic:Potential 2JZ-GE Atmo Power Gains
Next Topic:R31 skyline wheels on AE86 etc
Current Time: Fri Oct 23 21:40:19 UTC 2026
Total time taken to generate the page: 0.0044569969177246 seconds
