Toymods » Tech & Conversions » early MA61 out of tank fuel pump.
rob_RA40
c'town, NSW
early MA61 out of tank fuel pump. Tue, 25 November 2003 07:17 Go to next message
looking for some info for a friends 1JZ MA61 conversion.
does anyone know approx how much HP these pumps (same as MA45) can feed?
if a bosch high pressure pump is put in its place would the small amount of sucking it needs to do damage the pump? as i know they dont particularly like to suck.
[Updated on: Tue, 25 November 2003 07:18]
Re: early MA61 out of tank fuel pump. Tue, 25 November 2003 07:54 Go to previous messageGo to next message
why not just get a big in-tank pump?
edit: the stock pump is good for well over 200rwkw
[Updated on: Tue, 25 November 2003 07:55]
1jdavo
mboro
Re: early MA61 out of tank fuel pump. Tue, 25 November 2003 08:22 Go to previous messageGo to next message
i reckon u need an external bosch pump (as well as the current pump -read lift pump) run it of your fuel pump relay as i have on my mx83/chaser.
SkiDMaN
Gold Coast
Re: early MA61 out of tank fuel pump. Wed, 03 December 2003 12:37 Go to previous messageGo to next message
i had a external pump and surge tank on my ra65... *pretty much same setup as ma61* and i ditched that stuff and went for a internal 1jz soarer pump... works a treat Smile
ra23celica
Re: early MA61 out of tank fuel pump. Wed, 03 December 2003 23:01 Go to previous message
If its just a 1JZ (not GTE) the stock pump will flow enough for him, as stated its good for 200rwKw plus. If you want to try and improve on that a Bosch pump from a EFI Camira JB-JD flows more at higher pressure and is designed to be an externally fitted hi-flow pump. Rock on down to your local Nick-a-Part and try and find a 'fresh' Camira still with its original fuel pump.
Mitch.
Previous Topic:Diff Ratios
Next Topic:20V vs 16V 100kw Strength Question
Current Time: Fri Nov 20 12:47:19 UTC 2026
Total time taken to generate the page: 0.0057008266448975 seconds
