Classifieds » Parts Wanted » WTB: driverside window switch AW11 mr2
midnight
icon4.gif  WTB: driverside window switch AW11 mr2 Tue, 25 November 2003 08:48 Go to next message
Yeah I need a drivers side power window switch for an AW11 mr2..
Im sick of having to open my door every time I go through a toll...
feral4mr2
Bundaberg, Qld.
Re: WTB: driverside window switch AW11 mr2 Tue, 25 November 2003 10:21 Go to previous messageGo to next message
Freak i am replacing mine with Britax momentary on/off/on switches from work.
the only problem i have now with my drivers window is that damn plastic cog has stripped again... Mad
midnight
Re: WTB: driverside window switch AW11 mr2 Tue, 25 November 2003 10:27 Go to previous messageGo to next message
yeah Id prefer a replacement, because if I replace it using an alternate switch, I know i'll end up customising the whole module...
strange... seems when the driversside stopped working, putting the passenger window up from the driverside is no longer possible...
You wouldnt happen to have a wiring diagram for the power windows would you feral? it make things abit easyier
feral4mr2
Bundaberg, Qld.
Re: WTB: driverside window switch AW11 mr2 Tue, 25 November 2003 11:01 Go to previous messageGo to next message
http://publish.hometown.aol.com/feral4mr2/images/p owerwin.jpg
G = green
G-R = green w/red stripe
G-O = green w/orange stripe
G-Y = green w/yellow stripe
R = red
R-L = red w/blue stripe
L = blue
W-B = white w/black stripe
hope that helps..
midnight
Re: WTB: driverside window switch AW11 mr2 Tue, 25 November 2003 11:10 Go to previous messageGo to next message
cheers!
I disassembled the switch the other day and theres like a hundred connectors and points in there... and I was way to drunk to trace it... Laughing
still looking for a replacement tho...
davedave
Re: WTB: driverside window switch AW11 mr2 Wed, 26 November 2003 07:54 Go to previous messageGo to next message
Don't know if you've seen this before.
http://www.deru.com/~sgn1/AW11/Bodyre.htm
Sometimes the power windows will not work because the switch is just full of crud, and a good cleaning will fix the problem. Another problem is when the small center switch becomes wallowed out and will not make contact. A cheap fix for this is to take out the switch and carefully cut off the bump stop for the larger button and make the larger button work both up and down. Also, a non working window could also be from a snapped regulator cable.
And for the plastic Cog replacement http://www.twosrus.com/new/Lower_Frames/Products/F abricated/MKIwindowgear.htm might be cheaper than buyer a whole assembly.
feral4mr2
Bundaberg, Qld.
Re: WTB: driverside window switch AW11 mr2 Wed, 26 November 2003 08:06 Go to previous messageGo to next message
i have already started replaceing mine with Britax switches.
as for the cog, i have thought many times to buy a few from twosrus, just not too sure how much shipping would be.?
the last cog i made myself, toyota wanted $495 for the lot and wouldnt sell the cog seperately.
but the plastic has stripped again, i might have to buy the 'twosrus' cogs i think.
midnight
Re: WTB: driverside window switch AW11 mr2 Wed, 26 November 2003 15:02 Go to previous messageGo to next message
yeah the problem is the pervious owner tried to fix the switch ang most of its internals are missing.. cant do that fix Mad
midnight
Re: WTB: driverside window switch AW11 mr2 Thu, 04 December 2003 02:39 Go to previous message
bump
Previous Topic:AE86 indicator lever
Next Topic:1986 GT Soarer front bumper
Current Time: Sat Nov 21 15:26:58 UTC 2026
Total time taken to generate the page: 0.006479024887085 seconds
