Toymods » Tech & Conversions » valve sealing question
Mr DOHC
valve sealing question Tue, 25 November 2003 10:47 Go to next message
i have just got myself a spare 18RG head, i have lapped in the valves, and when i put the valves back in and pour water into the chambers to check for full sealing, it still leaks, no 2 leaks all out in about 30 mins but 1,3,4 only have about 1/2 left after 1.5 hours, will this small leakage affect compressions.
i have checked al the vaves with bearing blue and it comes up fine
Re: valve sealing question Tue, 25 November 2003 14:38 Go to previous messageGo to next message
this is with spring pressure?
you might need an engine shop to re-grind the valve seats and faces - should be a standard 3-angle job with a polish afterwards?
seeing as it's not in an engine you might as well give it refresh: valve seats, minor porting/polish, cleanup gasket surface, cleanup the spark-plug threads, etc)
charles.
allencr
tallahassee FL usOFa
Re: valve sealing question Tue, 25 November 2003 16:57 Go to previous messageGo to next message
water, with its surface tension(ever float a razor blade?), oughta stay FOREVER(except for evaporation) even with poor valve seats.
with springs installed and gasoline/petrol poured down the ports there should still be ZERO seepage with any newly ground/lapped valves.
Jason
Re: valve sealing question Tue, 25 November 2003 23:28 Go to previous messageGo to next message
Have you got a picture of the valve because it sounds pretty bad. Also you do have the springs and collets in etc dont you silly question i know.
Mr DOHC
Re: valve sealing question Wed, 26 November 2003 07:55 Go to previous messageGo to next message
no i dont have the springs in cause i dont have the tool, i have lapped them in with the rough paste then the smooth paste and checked with bearing blue and it has a very good sealing area (2mm+) on each valve.
Re: valve sealing question Wed, 26 November 2003 08:01 Go to previous messageGo to next message
they may not seal perfectly with no springs, but at rpm, with spring pressure (around 40-80lbs!!) they should seal okay. try the leak test with springs installed and see what happens.. should have buggerall leakage then.
when i was doing the CC'ing of my chambers, i cbf putting springs on, so put a light smear of grease to seal them, otherwise they'd leak. once springs were installed, no leakage..
allencr
Re: valve sealing question Wed, 26 November 2003 16:28 Go to previous messageGo to next message
"very good sealing area (2mm+)"
Wider is NOT better!! Toyota 4AGE spec is 1 -1.4mm
the seat does 2 things, seal and transfer heat(especially the exhaust), and you need the opposite seat widths for each so there has got to be a compromise. wide transfers better, but narrow seals better and is necessary to cut through & crush out the carbon deposits without going for stronger springs.
Mr DOHC
Re: valve sealing question Thu, 27 November 2003 09:37 Go to previous message
i re did the intakes last night and i did the bearing blue test and the are very good, just have to do the exh now
Previous Topic:steering problem on TA22(PLEASE HELP!!!!)
Next Topic:solex'z backfiring??
Current Time: Sat Nov 21 21:13:53 UTC 2026
Total time taken to generate the page: 0.005220890045166 seconds
