Toymods » Tech & Conversions » 4AGE overheating problem
tailz
4AGE overheating problem Tue, 25 November 2003 16:22 Go to next message
hi before i take my 4AGE bluetop AE82 to my mechanic i would like to ask for opinions since most of the toyota know it all are from here ...
well the situation is when i take my car for a drive it doesnt take anymore longer than 15 minutes before it reaches the first High Temperature line on my temp guage ... the car drives pretty normal when itz cold and warm enough to drive but then the temperature just keeps on rising ... this does not happen when it is left idling, only when i start to drive the car ... and i get very very anoyed because every 15 minutes i have to stop and wait till it gets cold ... the car however gets back to cold in no longer than 15 minutes ... i have already replaced my thermo stat and got my thermo fan checked and they all working fine ... i have also replaced my radiator cap since the old one was abit lose ... but this did not affect the problem ... the radiator is not leaking and is not losing compression since it was fully checked by my mechanic ... and everytime my rev goes back down it keeps going down untill the car stalls ... and itz anoying stalling everytime u let go of the accelerator ...
so now i am asuming it is iether the
* radiator core being blocked with mud and other stuff ...
or
* my head gasket is about to go and needs a new one ...
my friend has also advised me that it could well be my water pump
what is ur opinion ??
[Updated on: Tue, 25 November 2003 16:33]
allencr
tallahassee FL usOFa
Re: 4AGE overheating problem Tue, 25 November 2003 17:05 Go to previous messageGo to next message
it is not the water pump, unless it is leaking from the pump and the overheating is from lack of coolant.
tailz
Re: 4AGE overheating problem Tue, 25 November 2003 21:36 Go to previous messageGo to next message
okies well that crossed out the water pump from the list thanks ... but i dont think it has anything to do with the coolant ... i have checked it and itz still pretty green to me ... even the coolant bottle still has coolant in it ...
ae86trueno
Re: 4AGE overheating problem Wed, 26 November 2003 00:24 Go to previous messageGo to next message
check the thermastat isnt broken
Ben
AE86 Trueno 4AGE
GTStar
W.A.
Re: 4AGE overheating problem Wed, 26 November 2003 03:50 Go to previous messageGo to next message
check ur water hoses to make sure they are not blocked
FKN16V
NSW, East Coast
Re: 4AGE overheating problem Wed, 26 November 2003 11:34 Go to previous messageGo to next message
I'd be checking the operation of the water temp sensor, if your not leaking coolant and the motor gets hot while driving, this is very strange.
Wouldnt the water get hot while idling, due to lack of air flow.
When the temp rises, feel the temp of the radiator cap, if it almost burns your hand off then you have a problem, also listen for boiling water, if your temp is that high your water/coolant will be boiling.
Im thinking electrical fault somewhere.
Just my 2c worth
Hope it all works for ya
Grega
melbourne.victoria.austra...
Re: 4AGE overheating problem Wed, 26 November 2003 21:51 Go to previous messageGo to next message
what ae86trueno said.
and pull your radiator and give it flush while you're on the job.
tailz
Re: 4AGE overheating problem Thu, 27 November 2003 14:30 Go to previous messageGo to next message
aiight well thanks for all the help guyz ... i have tried a few of the suggestions ... so far this is the result ...
* thermo stat replaced with brand new
* radiator cap replaced with brand new
* head gasket test showed that the first cylinder showed very very low compression of 75 psi and the other 3 showed around 160 ...
so i am guessing i have blown a the head gasket but i have checked my radiator and no bubbles of oil or air has come out ... and also the water in my radiator doesnt look like itz flowing when i started the engine ... my friend showed me his water in his radiator when he turned it on and it was moving around like a current ... mine just sits der and doesnt really get hot so i am also guessing that ither my water pump is not functioning or my radiator blocked and that the water doesnt circulate around the engine ... i am going to flush it down tomorrow and hope for the best ...
thanks again for all the help on narrowing this problem down for me ... cheers ...
Re: 4AGE overheating problem Sat, 29 November 2003 08:14 Go to previous message
tailz wrote on Fri, 28 November 2003 00:30
thermos stat will only allow circulation when engien is warm - did you check water flow at running temps (warm engine up with radiator cap off).
charles
Previous Topic:Rear taillight leaking on AE92 Seca?
Next Topic:3T GTE head on 2TG??
Current Time: Fri Oct 16 13:05:17 UTC 2026
Total time taken to generate the page: 0.0052781105041504 seconds
