Toymods » Tech & Conversions » 4AGE into a 4AFE
SecaBoy
Brisbane, Mango Hill
4AGE into a 4AFE Thu, 27 November 2003 00:30 Go to next message
hello all...
I'm new here, so be nice... Razz
Ive read these forums alot and i notice that the question of 4AGE vs 4AGZE comes up a lot, so I'm not gonna ask them cause Ive already decided on a 4AGE from what Ive read on this forum... basically what I'm after is a guide on how much i should be paying and how long it should take.
i have a couple of questions:
1) Can the 4age engine be easily swapped for a 4afe?
2) Is there a lot of rewiring that needs doing?
3) How difficult is the whole job?
4) What is a guesstimate of how much it will cost? (labour wise)
5) How long will the conversion take to do?
Thanks HEAPS in advance
Ashley
STR8 2.8
Re: 4AGE into a 4AFE Fri, 28 November 2003 05:57 Go to previous messageGo to next message
i assume u mean swap the fe for the ge, not the other way around.
because why would you want to swap a 4age for a 4afe?
which 4age do you want?
Bill Sherwood
Brisbane / Gold Coast
Re: 4AGE into a 4AFE Fri, 28 November 2003 06:21 Go to previous messageGo to next message
Partial thread hi-jack here.
FWIW I'm not building any more 4AGE's because out of the six different 4AFE heads I've found so far, two are very bloody good indeed, and are better in just about every way than any 4AGE head.
(But I'm going to build a 7AGTE 20v though ....)
If you cna get one with the right head, I have no doubts it'd go very well indeed - Mine is currently getting parts gathered up to build it from March next year.
IRA11Y
Club Member
Re: 4AGE into a 4AFE Fri, 28 November 2003 06:26 Go to previous messageGo to next message
Wow Bill thats a big switch, care to share the specs/ basis of the reasoning behind the change? Smile
Bill Sherwood
Re: 4AGE into a 4AFE Fri, 28 November 2003 12:10 Go to previous messageGo to next message
Reasons for -
- 31mm buckets, so big cams aren't a problem at all.
- Narrower valve angle, 22.5°.
- MUCH better inlet port.
Reasons against -
- Squish areas are located in four areas Vs the G head's two large ones. I haven't measured them as such but I'd say the F head has about the same total area anyway though. So with work they're probably just as good but it's more work to get right.
- Hard to alter the lobe centres WRT each other unless you build a very small slotted drive gear between the cams.
- The exhaust ports also need a lot of work to get right. Cyls #2 & #3 are not too bad, but #1 & #4 are angled and need more work than the middle two. I plan on using ovaled ports, this'll make the job of making all the ports the same much easier.
- People think you're barking mad! Smile
IRA11Y
Club Member
Re: 4AGE into a 4AFE Fri, 28 November 2003 23:11 Go to previous messageGo to next message
Well not really Mad, ive always believed the FE head is better for low to mid range power, but the main constraint was always top end flow, i dont know if spending a large amount of time changing the squish and flow areas will give an equal benefit to the GE head in terms of maximum output for a lot less work.
Classique71
Colac, Victoria
Re: 4AGE into a 4AFE Sat, 29 November 2003 01:20 Go to previous messageGo to next message
Ive heard similat things about the 2t head VS 2tg head .. regarding flow and design ..
i wonder if its a common toyota thing
Bill Sherwood
Re: 4AGE into a 4AFE Sat, 29 November 2003 04:51 Go to previous messageGo to next message
IRA11Y wrote on Sat, 29 November 2003 10:11
Have you seen the head I'm talking about? It's not very common, like the crappy ones that are on the vast majority of 4AFE's.
I've no doubt that doing all that work will make the chamber a better one than a 16v, as I'm going to do some tricky stuff with the squish areas. Yes, it's hard to do but getting a lot of power out of little engines isn't always easy. Wink
IRA11Y
Club Member
Re: 4AGE into a 4AFE Sat, 29 November 2003 05:22 Go to previous messageGo to next message
Oh i diddnt know there were different series FE heads Bill? are they different depending on Carb or EFI series? or is it year by year?
got some comparitive pics of the heads?
Chris Davey
sunny coast, qld
Re: 4AGE into a 4AFE Sat, 29 November 2003 05:28 Go to previous messageGo to next message
that certainly was a good thread hijack! Smile
Johnny
Sydney, OZ
Re: 4AGE into a 4AFE Sun, 30 November 2003 01:33 Go to previous messageGo to next message
I do agree with bill, the only hassle I've had is those dam gear drives!... But I do have a few Ideas and sketches and excess of heads and gears to get something happening, but time is the thing I'm currently lacking. Another prob which can be easily fixed with these heads is the small exhaust valves which make them prone to ping if left in standard form. Any way the line up of FE heads is such... Eariler, late, 4AFE, 7AFE, Multi coil setup, and a couple of T-vis types-> One of the T-vis would be what Bill has and the ones I can't use (Anyone want one??)
SecaBoy
Re: 4AGE into a 4AFE Sun, 30 November 2003 21:48 Go to previous messageGo to next message
STR8 2.8 wrote on Fri, 28 November 2003 16:57
yeah, swap an fe for a ge... Wink
i dont really know as of yet... but im tending to go towards the silvertop... but what i want is an engine that will drop in without having to do modifications...
is this possible?
THanks
Ash
Bill Sherwood
Re: 4AGE into a 4AFE Mon, 01 December 2003 01:53 Go to previous messageGo to next message
No, the head I'm using isn't the TVIS head, though it's similar.
This is what they looks like ->
http://www.billzilla.org/7afe-1.jpg
THe one I'm talking about has only a single port, but it also comes down into the chamber at about a 45° angle like the twin-port one does. Very nice indeed.
FWIW, there's three basic types -
- The crappy side-port type.
- The type pictured above.
- The third type I mention above.
The 1st & 2nd types have either the injectors in the head or the manifold. The 3rd type has slightly different port dividers but they both have the injectors in the manifold.
There may be more subtle varaitions, but I haven't found them yet.
Johnny
Sydney, OZ
Re: 4AGE into a 4AFE Mon, 01 December 2003 02:40 Go to previous messageGo to next message
Bill looks very similar...doh!! I haven't uploaded the pic's on my page yet!! The two I have, have got a a bunch of butterflys mounted in a sandwich plate that fits between the Manifold and the head... Give me sometime and I'll finish the web page with every single 'A' series head that was sold.
IRA11Y
Club Member
Re: 4AGE into a 4AFE Mon, 01 December 2003 05:35 Go to previous messageGo to next message
Does the single port have a smaller area on one side? just imagining the head above machined out, is there a reason the secondary ports are smaller (TVIS butterfly side? )
Johnny
Sydney, OZ
Re: 4AGE into a 4AFE Tue, 02 December 2003 05:09 Go to previous messageGo to next message
from looking at the ones I have, the answer is yes, but I don't think Bill has machining the middle out in mind...
Bill Sherwood
Re: 4AGE into a 4AFE Wed, 03 December 2003 18:23 Go to previous messageGo to next message
IRA11Y wrote on Mon, 01 December 2003 16:35
Nah, the single port head has a rectangular hole.
Grega
melbourne.victoria.austra...
Re: 4AGE into a 4AFE Wed, 03 December 2003 22:11 Go to previous messageGo to next message
extremely interesting findings here bill...indeed.
IRA11Y
Club Member
Re: 4AGE into a 4AFE Thu, 04 December 2003 03:38 Go to previous message
not for long i expect Smile
Previous Topic:Looking at buying ST205 - inspection.
Next Topic:weight of 1g-gte
Current Time: Fri Nov 20 09:07:33 UTC 2026
Total time taken to generate the page: 0.0066688060760498 seconds
