Toymods » Tech & Conversions » steering problem on TA22(PLEASE HELP!!!!)
freakincage_com
north brisbane
steering problem on TA22(PLEASE HELP!!!!) Thu, 27 November 2003 04:58 Go to next message
hey i have a 72' TA22 and wen i am driving straight...the stering wheel can move a hald turn to the right with out moving the wheels..but as soon as i turn left it turns the wheels?? so its got bout half turn of play towards the right??? but it dosnt do it wen it is sitting still??? i reacintly replaced all the ball joints and the bushes...but it still does it???
[Updated on: Thu, 27 November 2003 05:01]
Re: steering problem on TA22(PLEASE HELP!!!!) Thu, 27 November 2003 11:28 Go to previous messageGo to next message
idler arm is loose/worn or the control arm has loose flogged-out tapers or gearbox is loose/worn or there's a loose ball-joint somewhere.
if you got someone to put in the ball joints etc get htem to re-check it. fwiw, the indroopilly bearupairs has a few guys who like celicas (one is in the Qld Celica Club) maybe they know more that your average suspension grunt.
fwiw: Ian Diffen World of Tyres (Taringa ) did my front suspension to get it roadworthy, they failed to tighten bolts all over the front suspension. maybe yours need same re-work?
charles.
freakincage_com
north brisbane
Re: steering problem on TA22(PLEASE HELP!!!!) Thu, 27 November 2003 11:37 Go to previous messageGo to next message
thanx man, i did the ball joints myself...they are all good....wats the idler arm...?
Re: steering problem on TA22(PLEASE HELP!!!!) Thu, 27 November 2003 11:42 Go to previous message
freakincage_com wrote on Thu, 27 November 2003 21:37
oops, so i guess they're pretty damn tight becuase the last thing you wanted to do was climb under the goddam car again to tighten a loose bolt Wink
idler arm is on pass side of engine bay, bolted to chassis rail - holds up other end of rod attached to steering box.
did you get a wheel align after doing the ball joints and bushes? sounds like one wheel's straight but the other just on the verge of turning.
charles.
Previous Topic:valve stem seals on the way out when....
Next Topic:valve sealing question
Current Time: Wed Oct 21 08:58:49 UTC 2026
Total time taken to generate the page: 0.072486162185669 seconds
