Toymods » Tech & Conversions » Legal limit of wheels on TA22??
freakincage_com
north brisbane
Legal limit of wheels on TA22?? Fri, 28 November 2003 08:01 Go to next message
hey, i have a TA22 celica and it is busy going throught the roadworthy, and they say that the mags i have on it are illegal??? they are only 195/50/r16??? any info will b apresiated...thanx
JoNo
Re: Legal limit of wheels on TA22?? Fri, 28 November 2003 08:11 Go to previous messageGo to next message
To be legal, the rolling diameter of your tyres must be close to the size of the factory-specified tyres. By my rough calculations, your tyres are about 50mm oversize which AFAIK isn't legal.
The other issue is you cannot alter the vehicle's original track width by too much (about 25mm is the limit I think), so if your new rims have a different offset that might be taking you into illegal territory.
peewee
adelaide
Re: Legal limit of wheels on TA22?? Fri, 28 November 2003 10:23 Go to previous messageGo to next message
i'm pretty sure that in many states the fact you're 3 inches bigger in diameter will kill you, the width and actual rolling size is often overlooked as the rim diameter is a quicker way for them to estimate it. or maybe some of the roadworthy guys actually think it's the rim that can't be more than 30mm or whatever the limit is, and not the actual rolling diameter
T APLUS 22
Re: Legal limit of wheels on TA22?? Fri, 28 November 2003 10:44 Go to previous messageGo to next message
well if they are 16" rims they should only have a profile of 40/45. Not 50!. And if they are 16 then why is the width only 195? I would of thought a 16x7" was the smallest width available on 16" rims, with a 7" width, it should be around the 205 mark. I'm not sure what the QLD RWC rules are. But down here in VIC if the car was made B4 1985 than it can have what ever size wheels it wants. lol. Otherwise it would be a limit of 2" larger in Diameter, and 1" larger in width. With what I was saying above about the recommended profile, the current rolling diameter of your current 195/50/16 will be larger than ti should. ie, my TA22 currently has 175/75/13, I will be going up to 205/45/16 or 205/40/16 have to re-check my figures. Hope this helps.
freakincage_com
north brisbane
Re: Legal limit of wheels on TA22?? Fri, 28 November 2003 10:48 Go to previous messageGo to next message
thanx guys...yer i kno the dimentions sound wierd but hey thats wat it says...aparently these mags where imported especially for the celica(previous owner) but i think i'll just buy some cheap stockies to keep them happy...
SeptemberSquallIndustries
Re: Legal limit of wheels on TA22?? Fri, 28 November 2003 12:41 Go to previous messageGo to next message
For Victorian owners I'd strongly recommend checking Vicroads Standards Information (VSI) articles 8 (modifications) and 26 (roadworthiness) as available for download from the Vicroads website.
Hay Jacob who said that pre-85 could have any size? In any case, I think you're right about the diameters you've specified for the 16".
http://www.miata.net/garage/tirecalc.html
Scorpion
Menai area of Sydney
Re: Legal limit of wheels on TA22?? Fri, 28 November 2003 23:21 Go to previous messageGo to next message
The rolling diameters of the 175x75x13 and 195x50x16 tyres are less than 2% different so the issue must be rim diameter. (The 205x45x16 is an almost perfect match.) If I recall correctly, in NSW you can only legally go to a rim 1" bigger than the largest rim that was fitted to the car as standard and a track 1" wider than standard. This is why a lot of people keep a set of stockies just in case they need them for rego. So you need to check the rules with your Qld traffic authority - they should have a website you can go to.
Re: Legal limit of wheels on TA22?? Fri, 28 November 2003 23:37 Go to previous messageGo to next message
2" in nsw
which means come 17" rim time, I'm gonna need an engineers cert for it
Scorpion
Re: Legal limit of wheels on TA22?? Fri, 28 November 2003 23:51 Go to previous messageGo to next message
UPDATE:
Try this site for Qld tyre/wheel limitations. It's a very interesting booklet that you can download - wish NSW had one like it. From Page 16 onwards is relevant for this thread.
http://www.transport.qld.gov.au/qt/driver.nsf/file s/images/$file/Vehicle-Modifications.pdf
Summary:
"The rim diameter may be varied from the standard size but the overall diameterof the tyre must not vary by more than +15 or -26mm" so your diameters are OK.
"The track of a car ... may be increased by up to 26mm beyond the maximum specified by the vehicle manufacturer for the particular model of the vehicle."
"The rims and tyres must not protrude beyond the bodywork of the vehicle, including flares, when viewed from above and when the wheels are facing straight ahead."
... and as an aside - "The fitting of spacers ... is not permitted."
[Updated on: Fri, 28 November 2003 23:52]
Scorpion
Re: Legal limit of wheels on TA22?? Sat, 29 November 2003 00:33 Go to previous message
Draven:
Have a look at this RTA Vehicle Standards Information No.9 for NSW.
http://www.rta.nsw.gov.au/registration/downloads/v si09_rev4.pdf
Disregard my diameter limit. Diameter limits are +15mm on largest standard rim/tyre combination and -15mm on smallest rim/tyre combination for that model of vehicle. 26mm wider than largest standard option is OK. There are ways to go bigger - see Sheet 9.
Have a look at this site for index of all NSW RTA Vehicle Information sheets.
http://www.rta.nsw.gov.au/registration/downloads/v ehicinfor_dl1.html
Previous Topic:NSW Vehicle Standards information
Next Topic:xA-6x Rusty TailGate what can be done?
Current Time: Sat Nov 21 19:05:49 UTC 2026
Total time taken to generate the page: 0.041139125823975 seconds
