Toymods » Tech & Conversions » brake upgrade for turbo-2TG on TA22
freakincage_com
north brisbane
brake upgrade for turbo-2TG on TA22 Sat, 29 November 2003 07:56 Go to next message
hey i was thingin of turbocharging my 2TG...yer i kno i said N/A all the way but way to much $$$$....i was woundering wat brake setups u gues would recomend???
CrAiGzEE
south of the big smoke
Re: brake upgrade for turbo-2TG on TA22 Sat, 29 November 2003 11:42 Go to previous messageGo to next message
Rolling Eyes Rolling Eyes Rolling Eyes
http://www.users.bigpond.com/digger_aus/search.gif
boris
On probation
Brisbane, Queensland
Re: brake upgrade for turbo-2TG on TA22 Sat, 29 November 2003 12:24 Go to previous messageGo to next message
Very Happy Very Happy Very Happy
Alchemist
Re: brake upgrade for turbo-2TG on TA22 Sat, 29 November 2003 12:30 Go to previous messageGo to next message
Oz_Craig : Smart arse Laughing Laughing but funny.
If I can remember properly, hilux struts/calipers & peugeot discs. I think some brake place sells them as a kit. But I'd do a search(no pun intended) to double check.
boris
On probation
Re: brake upgrade for turbo-2TG on TA22 Sat, 29 November 2003 12:34 Go to previous messageGo to next message
yep IDB automotive or something similar are meant to sell a kit. Has anybody ever bought one of these kits? if so how much was it and what do you think? Very Happy
[Updated on: Sat, 29 November 2003 12:35]
Re: brake upgrade for turbo-2TG on TA22 Sat, 29 November 2003 14:10 Go to previous messageGo to next message
and there's also a few brake articles on the main toymods site in teh article section:
http://www.toymods.org.au/sprinter_front_brakes
http://www.toymods.org.au/phill_brake
tho i'm not sure how different the TA22 front disks would be to RA23 and up.
charles.
SeptemberSquallIndustries
Re: brake upgrade for turbo-2TG on TA22 Sat, 29 November 2003 14:52 Go to previous messageGo to next message
thechuckster wrote on Sun, 30 November 2003 01:10
In short, enough. Though I do remember visiting IDB Automotive and being told first hand that two different TA22 brake upgrades were available in kit form or as roll-in/roll-out conversions.
CLG
Perth, Western Australia
Re: brake upgrade for turbo-2TG on TA22 Sat, 29 November 2003 15:43 Go to previous messageGo to next message
There's lots of options here, the cheapest and easiest is probably grabbing a set of RT132 struts and brakes complete, grinding off the larger lower spring perches and replacing with the smaller TA22 items, and bolting in with the TA22 strut tops! An extra 1.5" of brake rotor to grab, with twin spot callipers, and the basis of the Hilux 4 spot calliper/Puegoet vented rotor that is so popular. You'll also come away with larger wheel bearings, an advantage in many situations.
Grega
melbourne.victoria.austra...
Re: brake upgrade for turbo-2TG on TA22 Sat, 29 November 2003 21:09 Go to previous messageGo to next message
search is good, but
hilux calipers, xt130 struts, peugeot slightly modified rotors.
all go together apparently.
remember to also increase the ID of your master cylinder. extra fluid to push those extra pistons!
Re: brake upgrade for turbo-2TG on TA22 Sat, 29 November 2003 21:34 Go to previous messageGo to next message
RA40 struts, UZS131 rotors, mazda 4 spots
Or, if you're a little more keen, R33 Skyline brakes Evil or Very Mad I think I've described both before (search!), if any hassles, ask!
Evil_Foetus
Ballarat, Victoria
Re: brake upgrade for turbo-2TG on TA22 Sun, 30 November 2003 07:53 Go to previous messageGo to next message
Oz_Craig wrote on Sat, 29 November 2003 22:42
Laughing Laughing Laughing
ra23celica
Re: brake upgrade for turbo-2TG on TA22 Mon, 01 December 2003 00:46 Go to previous message
Any corona struts you bolt on to a TA22 are longer than the original struts so you are going to change your suspension geometry as a result. 'Search' for the DBA on-line catelogue and look through the Toyota section. You should be able to find a larger replacement rotor for your standard item that might only need a little machining to make fit. Then a pair of calipers to suit, using a custom adapter mounting plate, and you should be fine. Be careful with the wheels bearings you need in this combination as well.
Mitch.
Previous Topic:Rear Coilovers - INVERT
Next Topic:Total # Of 20 Valves Blacktop
Current Time: Thu Oct 22 05:04:29 UTC 2026
Total time taken to generate the page: 0.0058689117431641 seconds
