Toymods » Tech & Conversions » where does the CT26 get it's oil and water from? Also supra fuel pump question.
crazy_camry
where does the CT26 get it's oil and water from? Also supra fuel pump question. Sat, 29 November 2003 11:37 Go to next message
i'm doing a turbo converison on my 3s-fe, using a ct26, and am wondering where to get the oil from? i'm guessing from the oil sensor port, but any ideas on how to do this? i have the oil supply hard line and it has a banjo fitting on the end, does this meet up with the port? also for the water cooling, what lines should i splice into for this? and i dont have the fittings on the turbo to take the lines, just holes either side with screws to be able to mount something (also a blocking off plate for one of them), what should i do, go to toyota spare parts to get them? also on the oil return hard line, how is it connected to the sump?
as for the supra fuel pump, i thought another person that had done this conversion had used the jza80 TT supra fuel pump, then they said it was a "94-98 supra TT walbro 255lph fuel pump", so its not a stock pump? also he said "at 7psi you'll be running around 110psi of fuel pressure". i've got SUPRAMAN sourcing a stock TT supra fuel pump, would it do for these figures above?
sorry for my hard to understand post and ignorance, i'm very tired.
Re: where does the CT26 get it's oil and water from? Also supra fuel pump question. Sat, 29 November 2003 13:24 Go to previous messageGo to next message
110psi, are you sure about that?? That's more than 3 times the stock fuel pressure!
crazy_camry
Re: where does the CT26 get it's oil and water from? Also supra fuel pump question. Sat, 29 November 2003 23:13 Go to previous message
thats just what he said Confused
Previous Topic:Ae92 CS Sedan concept!
Next Topic:rotor exchange
Current Time: Thu Nov 26 05:16:55 UTC 2026
Total time taken to generate the page: 0.0057780742645264 seconds
