Toymods » Tech & Conversions » How to fit a fender?
fOOZ86
How to fit a fender? Sat, 29 November 2003 12:50 Go to next message
Hey all, I drive a sprinter and well, I've always had a bit of a problem with the door rubbing against the fender when you open it (drivers side door only) now I had a bit of a fiddle with it and it's worse than before, doh.
Is there any set procedure to follow when putting it on?. or could my car just be maybe out of alignment a bit?
Any suggestions on how to get this fixed? on a budget of course being a student and I'm trying to save for suspension parts, so if anyone could gimme a hand..
I'm trying to get it fixed by Monday, as I get my license back (from a six month suspension)..
One of the bolts also I think has threaded itself, the one just inside the door which I think I'll have to hacksaw off then drill out maybe, doh again.
I had a look through the toyota guide and they don't seem to mention it. Thanks, Grant.
jackel
Re: How to fit a fender? Sat, 29 November 2003 12:54 Go to previous messageGo to next message
Confused it should bolt right up if you have the correct fender cause it took like 5 minutes to do mine...
and if your door can close properly then it out of alignment Razz
fOOZ86
Re: How to fit a fender? Sat, 29 November 2003 13:00 Go to previous messageGo to next message
hmm, damn, the door has really messed up the bit on the fender, dang, back to the drawing board .. Maybe I should just weld the door shut or something, anyone got any suggestions?
CLG
Perth, Western Australia
Re: How to fit a fender? Sat, 29 November 2003 15:35 Go to previous messageGo to next message
Start from the rear of the door, making the door gap equal down the meeting face, then tighten the door bolts. Next loose fit the fender, or loosen so you can adjust it back and forth. Again make sure the gap is equal along the meeting face, and also make sure the door doesn't catch the trailing edge of the fender.
If the fender is bent along that edge, you'll have to panel beat it back into alignment, the joy of an AE86 is you can usually do this with your hands to some extent. Once it clears the door comfortably, start to tighten the mounting bolts, checking the bonnet meeting face as you go also for equal gap!
fOOZ86
Re: How to fit a fender? Sat, 29 November 2003 16:52 Go to previous message
Thanks, I'll give that a shot tomorow, I should've really thought about adjusting the door, hm.
Previous Topic:rotor exchange
Next Topic:Rear taillight leaking on AE92 Seca?
Current Time: Mon Oct 12 18:33:23 UTC 2026
Total time taken to generate the page: 0.072880983352661 seconds
