Toymods » Tech & Conversions » How do i set up this fan successfully?
V8_MA61
icon12.gif  How do i set up this fan successfully? Sun, 30 November 2003 08:52 Go to next message
Ok i'm going to keep my other car for summer, it doesnt have an electric fan, only a big ass clutch fan (and it also has a/c..but no spec fan for it.
so, for summer im installing an electric fan as an extra bit of cooling whilst im stuck in traffic with the a/c on.
I want to do the following:
-Have a switch in the car so i can turn it on and off at will.
- And also have it like a thermally controlled one...where after i turn the car off, the fan keeps going to prevent heatsoak.
Note: i dont want the fan running off a thermostat..as i only want to run it at will.
Ive got a relay and switch already...just need to know how i can go about doing the above?
Blake.
Re: How do i set up this fan successfully? Sun, 30 November 2003 10:20 Go to previous messageGo to next message
set up a thermo switch and dash switch in series.
that way only when they're both in the "on" position will the fan run
V8_MA61
Re: How do i set up this fan successfully? Sun, 30 November 2003 10:28 Go to previous messageGo to next message
I sorta dont understand what you mean Confused
Because i wanted to run the fan two ways..and if i have both switches in the "on" position, it will run anyway because the override is turned on.
What does this "thermal switch" look like?
Blake.
Re: How do i set up this fan successfully? Sun, 30 November 2003 10:49 Go to previous messageGo to next message
hi blake
V8_MA61 wrote on Sun, 30 November 2003 18:52
<snip>
wiring up relay...
-put the relay in an easy-to-get-to spot (engine bay)
-find a power line feeding horn or brake lights (this is fused but not switched by the Ig key or something)
-take a feed from that and make it power to the solenoid in the relay (so relay solenoid always has power)
-take other coil line from relay into cabin to switch
-other side of switch then goes to earth
-actual power to fans should come from battery or main power leaving the alternator (you have big fuse box in bay still?)
-power goes to relay (put a big inline fuse somewhere between power source and relay)
- then send power from relay to your fan with then earths the return line somwhere nearby.
Delaying it? (like a turbo timer) you need to know when the ign key is on/off so you can then use that power to a a relay that cuts into the line from relay solenoid to your cabin switch.
simplified concept: use Ign power to charge up a capacitor(s), when Ign power falls to zero, use stored charge to keep relay closed, the more stored charge, the longer relay stays closed, when charges is gone relay opens, cabin switch cannot switch main relay solenoid to earth and fans turn off. A bypass switch would go around the delay relay - tho if you leave bypass on and go outon the piss, you have to jump-start car next morning.
i'll try find the diagram that i used for by turbo timer and have a go at modifying it for you.
this help?
charles.
V8_MA61
Re: How do i set up this fan successfully? Sun, 30 November 2003 10:57 Go to previous messageGo to next message
Thanks a heap charles...yeah i think that makes more sense! Thatd be excellent if you could send me a copy of how to do it...i mean setting up the fan on a switch and relay isnt hard, just combining them is a pita...
Blake.
V8_MA61
Re: How do i set up this fan successfully? Sun, 30 November 2003 11:23 Go to previous message
the relay i have is actually a 6-terminal one.
c1+c2 - go to the switch i imagine
b - power from battery
L - im guessing + power to the fan?
Ive also got a 4 pin toyota one, ill wait and see which one i will use though...
Blake.
Previous Topic:22r-e cam
Next Topic:thermo fans
Current Time: Sat Oct 17 23:25:03 UTC 2026
Total time taken to generate the page: 0.0097241401672363 seconds
