Toymods » Tech & Conversions » T18 LSD
Connor
Devonport, Tasmania
T18 LSD Sun, 30 November 2003 09:51 Go to next message
hey, i'm gonna do a 3t gte conversion late nxt year, and prolly go with a corona tailshaft i think, as they bolt to the stock diff, but what options do i have in the range of lsd's? would i have to go a new arse end? and tailshaft? and this doesnt include a locker courtesy of boc gases:P
connor
[Updated on: Sun, 30 November 2003 09:55]
TE72_Turbo
Re: T18 LSD Sun, 30 November 2003 10:31 Go to previous messageGo to next message
Since you have a T series diff, all you need is the LSD hemisphere as often advertised for AE86 Jap sprinters. I think Kristian (SupraMan) has posted them on here for as low as $600 in good condition. Most people will try and rip you off upwards of $900 though, thanks to the AE86 "drift" craze.
Or you can do like I did and fit a Mark 2 Corona F series diff, they are only 5mm wider in total than the T18 diff, just swap all the mounts over. Axles are much bigger... Very Happy
Connor
Devonport, Tasmania
Re: T18 LSD Sun, 30 November 2003 10:35 Go to previous messageGo to next message
so the corona'd be the way to then hey:P i'm a new comer to doin this shit...so dont suppose u have a detailed list of the stuff that i'd need to do? lol
TE72_Turbo
Re: T18 LSD Sun, 30 November 2003 11:31 Go to previous messageGo to next message
If you do go the corona way, you will need to cut all of the trailing arm/panhard rod mounts off your T18 diff, and transplant them onto the corona diff... Any diff shop can do this for you, but its certainly not as cheap or easy as just bolting an LSD centre into your current diff.
Re: T18 LSD Sun, 30 November 2003 22:19 Go to previous messageGo to next message
I might add that Corona MkII's don't come with an LSD from the factory, so you still need to source an F series LSD from somewhere (eg MA61 Supra).
TE72_Turbo
Re: T18 LSD Mon, 01 December 2003 07:43 Go to previous messageGo to next message
yep
SeptemberSquallIndustries
Re: T18 LSD Mon, 01 December 2003 12:47 Go to previous messageGo to next message
Pardon my ignorance, but could I assume that this LSD hemisphere will suit a 2T TA22 rear end too?
TE72_Turbo
Re: T18 LSD Mon, 01 December 2003 12:52 Go to previous messageGo to next message
Yep, just make sure you get an LSD with the correct axle size. I belive there are differences between TRD/KAAZ etc.
sprinterboy4agze
Re: T18 LSD Mon, 01 December 2003 19:50 Go to previous messageGo to next message
this can be applied to the ae86 too right? are they strong diffs? how are they rated against r31 diffs?
TE72_Turbo
Re: T18 LSD Mon, 01 December 2003 21:13 Go to previous message
Sprinterboy: Are you asking about the F series diff? If so, yes, it would apply to the AE86, but it will be approx 30mm wider in total than your original diff, so you would need different offset wheels.
The F series diff is 7.5" crown wheel, and has 27 spline 28mm axles. I dont believe they are any weaker than an R31 diff, but they are not as easy to find LSD centres for, unlike the R31 (being a common Borg Warner)
Previous Topic:Unusual question... RAISING the ride height?
Next Topic:2TB/ 2TG,
Current Time: Sun Oct 18 20:07:10 UTC 2026
Total time taken to generate the page: 0.0045559406280518 seconds
