Toymods » Tech & Conversions » new diff
ENVYS-SR20
new diff Sun, 30 November 2003 11:36 Go to next message
i got my car back on sat morning, after having the turbo replaced cause i blew it up. i only had the car 1 day, and the diff decides 2 give up. so im after sum ideas on what diff 2 put in the car. its a 74 TA 22, and the diff needs 2 stand up to 210 rwkw. im thinking of putting a standard one back in just 2 get me around till i can find a new one, seeing as though the car is off the road more than it is on atm.
adam
Evil_Foetus
Ballarat, Victoria
Re: new diff Sun, 30 November 2003 11:42 Go to previous messageGo to next message
ask this in the tech section and i think more people will be able to look at it, so more help will come Surprised
i dont really know, but maybe an ma61 diff??? dunno........ Surprised
Classique71
Colac, Victoria
Re: new diff Mon, 01 December 2003 08:49 Go to previous messageGo to next message
use a hilux diff or a borg warner jobbie - preffered LSD..
I think Cool1 has a borg warner - but a non LSD for grabs ..
Hilux is strong enough - and its been covered a few times in the tech section on the install process
improvedae86
Re: new diff Tue, 02 December 2003 04:38 Go to previous messageGo to next message
How wide is the ta22 rear ? . And how hard are you driving it .
That sr torque is great at braking them isn't it . You getting wheelspin at 130ish with 210 rwkw or does the extra weight of the celica over a sprinter help that .
ENVYS-SR20
Re: new diff Thu, 04 December 2003 06:14 Go to previous messageGo to next message
ive put a standard diff back in for the moment, and just taking it a lil easy. im thinkin i mite get a hilux diff, ill have a look in the tech section see whats involved.
'improvedae86': wheel spin at 130??? havent had that yet, but as i said im takin it easy untill i get the new diff. jsut had another tune on the dyno and it made 220rwkw, so i wonder whats next 2 replace Sad
adam
Grega
melbourne.victoria.austra...
Re: new diff Thu, 04 December 2003 06:19 Go to previous messageGo to next message
improved86. ta22 lighter than ae86 methinks
adam, i'd look at a borg warner 78 series diff (VL onwards) shortened with EITHER kaaz LSD or B/W LSD.
the kaaz is the better bet tho - about $1700 - meridian motorsport will hook you up PM me if you wanna know a bit more
fucking great color too aye that ta22 same as mine (well same after respray - using GREY primer instead of the ghey RED) Smile
[Updated on: Thu, 04 December 2003 06:20]
improvedae86
Re: new diff Thu, 04 December 2003 06:53 Go to previous messageGo to next message
All very good but what is the size across from disc to disc ? You could use a crown housing with a modified ma61 centre or tarago etc or skyline r31 , the borg warner is expensive , if you cannot find a worn centre , I was quoted $650 for the 3.9 gear set then had to by the carrier , so i went away from that idea , and the hilux is a heavy unit , could be ok in a ta22 , but you stuff weight split on a ae86 even with extra kg's in the front , And once again expensive . You should be able to make yourself a diff to handle the sr20 power of 220kw with 280mmish rear disc lsd ford 9" size axles from around $1000 depending on the gearing you want to fit , i have the a 3.89 ,for the correct speedo gearing on the road but can fit a 3.7 4.11 4.44 in car without removing the diff .
ENVYS-SR20
Re: new diff Mon, 08 December 2003 07:04 Go to previous messageGo to next message
GRRRRRRR Mad , and there goes another diff, and i was trying to be careful. i guess its time for a stronger one, anyone know any decent places where i can get it done, around ringwood or surrounding areas. a rough price would be helpful aswell..
adam
improvedae86
Re: new diff Mon, 08 December 2003 08:01 Go to previous message
I must be talking to myself here !!
Previous Topic:18rc head onto 18rgu block
Next Topic:Fuel Pump - 2TGEU
Current Time: Sat Oct 31 16:41:34 UTC 2026
Total time taken to generate the page: 0.0047130584716797 seconds
