Toymods » Tech & Conversions » how to tell if valve guides are FUBAR'd
Mr DOHC
how to tell if valve guides are FUBAR'd Mon, 01 December 2003 12:33 Go to next message
hot can i tell when i have the head off, is there a lateral movement test
ed_ma61
Lost in the K hole
Re: how to tell if valve guides are FUBAR'd Mon, 01 December 2003 13:16 Go to previous messageGo to next message
yes, in the manual, there should be a tolerance for total lateral mvt of the stem when the valve is at full lift.
alternatively, take it to any machinist, and they can measure the internal valve guide dia with a ball gauge, and check it against wear of the vlave stem - yielding total clearance specs.
fwiw: the toyota guide material is VERY durable, and the allowable tolerance limits are very forgiving. only after maojr trauma or milions of miles should they be so far outta spec that they need replacing.
my 7m, for eg, was within FACTORY tolerances at 220000km, let alone any wear limit. my head builder also said pretty much the same.
ed
Re: how to tell if valve guides are FUBAR'd Mon, 01 December 2003 13:36 Go to previous messageGo to next message
Don't forget there are external factory that can cause premature wear.
I'm sure overheating, over revving, running low on oil can't help it.
According to the place that did my head, the exhaust guides were gone (I never asked how much, or whatever, in hindsight I should have)
gmsta27
Fl
Re: how to tell if valve guides are FUBAR'd Tue, 02 December 2003 02:50 Go to previous messageGo to next message
If you have the head off and can afford them change the guides for bronze guides. Better for performance and cooling.
Greg
Mr DOHC
Re: how to tell if valve guides are FUBAR'd Tue, 02 December 2003 08:52 Go to previous message
CrUZsida wrote on Mon, 01 December 2003 23:36
over revving
Rolling Eyes Rolling Eyes
8000+rpm???????????? Very Happy
the toyota 18rg book only tells me if i had a inside dial gauge
[Updated on: Tue, 02 December 2003 08:56]
Previous Topic:w55 gearbox
Next Topic:18rg performance mods?
Current Time: Fri Oct 23 13:37:17 UTC 2026
Total time taken to generate the page: 0.0047330856323242 seconds
