Toymods » Tech & Conversions » 4AGE 88kw with 100kw bottom end ??
tailz
4AGE 88kw with 100kw bottom end ?? Mon, 01 December 2003 19:36 Go to next message
heyz i currently have an 88kw 4age and was wondering if it is possible to drop a 100kw bottom end and still leave the TVIS active ... i have heared of such ideas a few times but i dont know if this actually works and how it goes on performance vs. maintenance cost ...
would this also be a big job converting ?? or would it be relatively easy for a mechanic to do ?? coz my head gasket is about to go and my rings are worn out and i think it would be cheaper for me to just do this ...
one more thing ... id still have to get my engine number changed if i decide to do this right ??
any tips are appreciated ...
cheers ...
TE72_Turbo
Re: 4AGE 88kw with 100kw bottom end ?? Mon, 01 December 2003 21:15 Go to previous messageGo to next message
Yes, you would need the engine number changed, as its stamped into the engine block.
The bigport head will bolt up to the 100kw block, with the TVIS manifold, but what computer would you use? You'd need to block the return hole in the 100kw block that is meant to be connected to an external oil drain on the 100kw head, which you obviously wont have with the old head.
Phil
._T_.
Re: 4AGE 88kw with 100kw bottom end ?? Mon, 01 December 2003 21:32 Go to previous messageGo to next message
this is an easy mod, and works very well. you use the 86kw ecu. you get a lot more mid-range torque, but run out of puff at top (fixed with slightly larger cams)
easy to update the engine number with the rego authorities.
T
GTStar
W.A.
Re: 4AGE 88kw with 100kw bottom end ?? Tue, 02 December 2003 02:52 Go to previous messageGo to next message
what kinda cams do you recommend? intake & exhaust ?
ae86trueno
Re: 4AGE 88kw with 100kw bottom end ?? Tue, 02 December 2003 03:30 Go to previous messageGo to next message
Max is 264 DEG with stock computer,
Ben
AE86 Trueno 4AGE
IRA11Y
Club Member
Re: 4AGE 88kw with 100kw bottom end ?? Tue, 02 December 2003 05:12 Go to previous messageGo to next message
264 or 272 depending on what you read and who you believe "shrugs"
oh and thats with standard lift.. if you start changing the lift then its another kettle of fish
tailz
Re: 4AGE 88kw with 100kw bottom end ?? Tue, 02 December 2003 07:39 Go to previous messageGo to next message
so how well would this actually go against the 20v and the 100kw on performance vs maintenance and cost ??
ae86trueno
Re: 4AGE 88kw with 100kw bottom end ?? Tue, 02 December 2003 11:03 Go to previous messageGo to next message
(Sorry for thread hijack)
Hi Michael
I am going to have to try this out just to prove once and for all if it can be done or not.
I will try the 272 Deg first, if it works, ill keep em in my engine and if they dont i will sell them here..
Ben
AE86 Trueno 4AGE
tailz
Re: 4AGE 88kw with 100kw bottom end ?? Tue, 02 December 2003 16:39 Go to previous messageGo to next message
by the way 1 more thing ?? will i have to do the wiring and loom again if i decide to do this ?? or would this be a total straight bolt on besides the TVIS head ??
Grega
melbourne.victoria.austra...
Re: 4AGE 88kw with 100kw bottom end ?? Tue, 02 December 2003 20:30 Go to previous messageGo to next message
depends, if you put in a 100kw bottom end, then, your TVIS and all the bigport stuff will remain - so - wiring will not have to change at all. however you will have to block off the drain at the inlet side of the bloack (at the back) from the 100kw head as you'll be using the bigport head. either that or bore a hole in the 86kw head to facilitate this?
however if you put a complete 100kw motor in then a few things have to change.
i drove the motor that T built in an MR2 - 100kw bottom end with bigport top end - was sensational - highly recommended!
[Updated on: Tue, 02 December 2003 20:33]
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: 4AGE 88kw with 100kw bottom end ?? Tue, 02 December 2003 23:45 Go to previous messageGo to next message
Im running a small port 100kw motor with a bigport ECU, thinking about chucking in some Bigport cams in there since they are slightly different from stock
worth doing?
._T_.
Re: 4AGE 88kw with 100kw bottom end ?? Tue, 02 December 2003 23:49 Go to previous messageGo to next message
smallport cams are 230 duration.
bigport cams, from ae86 or aw11 ONLY (!!) are 240 duration. fwd corolla type motor is 230.
worth about 5kw apparently (only .1 more lift)
T
TE72_Turbo
Re: 4AGE 88kw with 100kw bottom end ?? Wed, 03 December 2003 09:41 Go to previous messageGo to next message
Really? There's gonna be a few disappointed people out there who have sought "bigport" cams thinking they are 240 duration... Glad mine are actually from an AE86 import motor Smile
GTStar
W.A.
Re: 4AGE 88kw with 100kw bottom end ?? Wed, 03 December 2003 11:30 Go to previous messageGo to next message
so T what cams are u running in ure blueop head/redtop bottom config? and what lift are they??
are u still running the std. ecu?
._T_.
Re: 4AGE 88kw with 100kw bottom end ?? Wed, 03 December 2003 21:56 Go to previous messageGo to next message
that car was sold some time ago (currently building up a 3sge t-bar aw11)
it ran 240's, modified blacktop extractors and 2.5" exhaust (a bit loud) but boy did it go!! had heaps more mid-range than my sx, but the sx had more go up top (hence the need for bigger cams)
T
tailz
Re: 4AGE 88kw with 100kw bottom end ?? Thu, 04 December 2003 22:38 Go to previous messageGo to next message
okies i have spoken to a mechanic that does toyota only ... he seems to have a very good knowledge and reputation about toyota but he told me that this is not possible due to the redtop being a diff engine to the bluetop ... i dont know if his lying or just doesnt know of this setup since most of you would agree that this can be done fairly easily ... so now i dont know what to do coz my head gasket is going worser and worser and i need to make a quick decision ... if anyone out there know anyone who does this sort of service for a reasonable price please let me know as i will be needing to do this conversion or itz going to be a replacement for a new head gasket which will cost pretty alot ...
Re: 4AGE 88kw with 100kw bottom end ?? Thu, 04 December 2003 23:10 Go to previous messageGo to next message
I'd be more inclined to listen to people on here who have had first hand experience than a mechanic.
tailz
Re: 4AGE 88kw with 100kw bottom end ?? Thu, 04 December 2003 23:18 Go to previous messageGo to next message
thatz what i mean dude ... id rather someone whos actually done this before than someone who hasnt even heared of this kind of setup ...
._T_.
Re: 4AGE 88kw with 100kw bottom end ?? Fri, 05 December 2003 02:31 Go to previous messageGo to next message
it does go together - i should know!! the block is basically the same (minor casting differences due to the 100kw being the later 7 rib block) the heads all interchange.
T
IRA11Y
Club Member
Re: 4AGE 88kw with 100kw bottom end ?? Fri, 05 December 2003 08:55 Go to previous messageGo to next message
yep many of us can vouch the interchangeability of the blocks and heads, ive even used a 4A-C block and substituted GE running gear and put a bigport head on it ( was a desperate time LOL )
as mentioned before you just need to decide what harness computer and injectors you want to run and if you use the bigport head youll need to block off the oil drain on the 100Kw block ( not all of them have this either )
Ben, id be happy to see the results, you know id give you my set of cams to try but itd be too much haslle now to pull it all out so close to getting it all in. ive got a bigport ecu and stuff here to try ( is yours a 100Kw or 86Kw? ) also got some news for you regarding MSquirt, we may need a donor car for testing next year sometime Wink
Edit: Ben i can allready confirm 262 runs on a stock 100Kw ecu and it hasnt even been dyno tuned yet. Does have Adj cam gears though.
[Updated on: Fri, 05 December 2003 08:57]
ae86trueno
Re: 4AGE 88kw with 100kw bottom end ?? Fri, 05 December 2003 09:19 Go to previous messageGo to next message
Yeah i already knew the 262 would work, its just the 274 that everyone seems unsure about. Although by my calculations my 86KW injectors may not be enough and the engine will run way too lean, and the only other injectors i have at the moment are GZE ones which wont work with my Bigpot computer.
Is that engine Sams by any chance ??
As for the MSquirt the car is here any time you need it id be up to try that.
Ben.
IRA11Y
Club Member
Re: 4AGE 88kw with 100kw bottom end ?? Fri, 05 December 2003 09:23 Go to previous message
Yeah Sams car
I sent you a PM on the MS
Previous Topic:4a's and GT30's
Next Topic:exhaust manifold
Current Time: Thu Nov 19 23:00:14 UTC 2026
Total time taken to generate the page: 0.0079159736633301 seconds
