Toymods » Tech & Conversions » Pitted block surface
ViNcEnXo
Pitted block surface Tue, 02 December 2003 08:35 Go to next message
The mechanic pulled the head of the Soarer today, yep, blown head gasket but it's also got a pitted block around the pistons...
What can I do? Any advice?
Mr DOHC
Re: Pitted block surface Tue, 02 December 2003 08:41 Go to previous messageGo to next message
pitted in the bore or on the deck, the deck will always look pitted when u pull the head off, FULLY clean the deck {use an air whizzer} and it should be fine, bores: re-bore, new pistons, new rings $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Re: Pitted block surface Tue, 02 December 2003 11:36 Go to previous messageGo to next message
Pics please.....depending on location and size you may have to deck the block.....grief.
ed_ma61
Lost in the K hole
Re: Pitted block surface Tue, 02 December 2003 11:50 Go to previous messageGo to next message
philmelvin wrote on Tue, 02 December 2003 19:41
whoa... BIG assumption
like GT said, pics, as well as straight gauge measurements would be good to know.
7m's have a habbit of having bad deck surfaces...
ViNcEnXo
Re: Pitted block surface Tue, 02 December 2003 11:56 Go to previous messageGo to next message
I don't know if I could get pics, I haven't even seen it myself.
Just going by what the mechanic has said.
Mr DOHC
Re: Pitted block surface Tue, 02 December 2003 12:00 Go to previous messageGo to next message
ed_ma61 wrote on Tue, 02 December 2003 21:50
oh, i didnt know that 7m's had that issue as well, i just thought it was a head design issue Embarassed
ed_ma61
Lost in the K hole
Re: Pitted block surface Tue, 02 December 2003 12:19 Go to previous messageGo to next message
dont know if its really 7m specific, or just a trait of 15 year old block castings combined with a long I6 block type...
also chuck in poor coolant maintenance
just as an anecdote, i know 7m blocks to wander, and badly corrode around water channels.
ViNcEnXo
Re: Pitted block surface Tue, 02 December 2003 22:46 Go to previous messageGo to next message
Mechanic says it's corroded around the water channels and around the piston holes.
Re: Pitted block surface Tue, 02 December 2003 22:48 Go to previous messageGo to next message
water channels - it happens. as long as it's not too severe, not much to worry about.
piston bores is much more of a worry... an expensive worry
ViNcEnXo
Re: Pitted block surface Tue, 02 December 2003 22:49 Go to previous messageGo to next message
It's about 5mm away from the actual hole.
Keep in mind I have a HKS metal head gasket and ARP bolts waiting to go in.
ed_ma61
Lost in the K hole
Re: Pitted block surface Wed, 03 December 2003 01:01 Go to previous messageGo to next message
deck it
pita, but worth the hassle
deck it
ViNcEnXo
Re: Pitted block surface Wed, 03 December 2003 01:04 Go to previous messageGo to next message
ed_ma61
Lost in the K hole
Re: Pitted block surface Wed, 03 December 2003 01:09 Go to previous messageGo to next message
actual machining, $80
getting the guy to pull the block out.... Rolling Eyes
(herin lies the joy of doing things yourself)
is definitely worth asking him.
and ask youself, how much are you spending so far, and do you want to compromise that expense by not spending a bit more Sad
Re: Pitted block surface Wed, 03 December 2003 01:10 Go to previous messageGo to next message
*perves on ed's sexy new avatar*
ViNcEnXo
Re: Pitted block surface Wed, 03 December 2003 01:19 Go to previous messageGo to next message
So far $280 for head gasket,
$200 for ARP bolts.
Approxx $400 for labour.
$100 for head to be machined.
Does the engine have to be dismantled for the block to be decked??
The engine has only got 100,000 k's on it, and apart from a BHG causing corrosion of the surface, it's really good.
Re: Pitted block surface Wed, 03 December 2003 01:25 Go to previous messageGo to next message
ViNcEnXo wrote on Wed, 03 December 2003 12:19
Yes.
Therein lies the problem. If the pitting is bad or badly placed, it's actually a fucked motor.
ViNcEnXo
Re: Pitted block surface Wed, 03 December 2003 01:33 Go to previous messageGo to next message
Hmm, mechanic is going to have his engine reco-er look at it.
Re: Pitted block surface Wed, 03 December 2003 03:45 Go to previous messageGo to next message
Certainly get someone well versed at these things to look at it - the surfaces have to be pretty good to tolerate a MHG. You may wish to use the standard head gasket and run standard boost - this should be a bit more forgiving of suspect surfaces.
However: Don't trust any of us - we haven't seen it nor are we in the business of rebuilding engines.
It's not the end of the world if you choose to deck it - it will give you an opportunity to freshen it up a bit with new rings and bearings if you so desire.
If your ultimate plan was to do some sort of conversion, then you may wish to do the sums on patch up repair and replace versus a proper repair job.
ViNcEnXo
Re: Pitted block surface Wed, 03 December 2003 06:12 Go to previous messageGo to next message
http://www.bretts.com.au/homeware/assets/images/block.jpg
http://www.bretts.com.au/homeware/assets/images/block3.jpg
[Updated on: Wed, 03 December 2003 06:15]
Mr DOHC
Re: Pitted block surface Wed, 03 December 2003 07:14 Go to previous messageGo to next message
the waer channels look fine TO ME, but that "dent" {corrosion} looks bad Rolling Eyes
ViNcEnXo
Re: Pitted block surface Wed, 03 December 2003 08:58 Go to previous messageGo to next message
Going to get the block decked. Not going to do it poorly. I've bought the best parts possible so far, I am not going to stop now.
ed_ma61
Lost in the K hole
Re: Pitted block surface Wed, 03 December 2003 09:35 Go to previous messageGo to next message
the corrosion around the water channels isnt great... but is FAR from the worst ive seen, and on those two shots, isnt approaching the cyl bore in any serious way. still, they could definietly benefit from a shave...
the ring around the comb chamber is FAR more concerning as this is the EXACT location of the fire ring of the head gasket - ie where the gasket seals. id be wanting to machine it so the was zero evidence of that ring depression left...
you may encounter some increase in compression with this though, and your cam timing may be out.
if you can tell me how much gets taken off the head and block in total (exactly), i can advise you how to set up your cam gears to compensate.
i doubt the compression increase will be a serious issue. if you have concerns though, i can show you some spots to relive the comb chambers... Very Happy
Re: Pitted block surface Wed, 03 December 2003 10:14 Go to previous messageGo to next message
Ed: if you heavily machined the block to removed the dents from the gasket rings, would you get too close to pistons hitting valves? even with modified timing on the cams
i know i'm displaying complete lack of knowledge of 7M's here but am just curious...
charles.
ed_ma61
Lost in the K hole
Re: Pitted block surface Wed, 03 December 2003 11:00 Go to previous messageGo to next message
thechuckster wrote on Wed, 03 December 2003 21:14
not a chance - you can land a boeing in the space between the valves and pistons of a 7m Laughing
tafebum
Re: Pitted block surface Thu, 04 December 2003 11:37 Go to previous message
thats looks mighty good compared to what i found on my GE, although this is the head. Sad
http://home.iprimus.com.au/thekirbys/Picture 002.jpg
Previous Topic:Soarer rear tail lights? How do you get at them?
Next Topic:TA22 fuel line size
Current Time: Fri Nov 20 08:45:59 UTC 2026
Total time taken to generate the page: 0.0069239139556885 seconds
