Toymods » Tech & Conversions » 4ac temp sensor question. help please!!
gabe
4ac temp sensor question. help please!! Tue, 02 December 2003 10:18 Go to next message
Does anyone know what resistance the temp sensor should read at cold and at operating temp??
Accurate resistances would be appreciated thanks.
[Updated on: Tue, 02 December 2003 10:32]
Scorpion
Menai area of Sydney
Re: 4ac temp sensor question. help please!! Tue, 02 December 2003 10:43 Go to previous messageGo to next message
Toyota service manual provides the following resistance figures between the terminal and ground ...
At 50 deg C (122 deg F) => 226 ohms
with tolerance (+33.6 / -36.6)
At 115 deg C (239 deg F) => 26.4 ohms
with tolerance (+1.71 / -2.21)
No figure for cold but presume might be 226 ohms +33.6
i.e between 226 and 259.6 ohms
Hope this helps.
What problem, if any, are you having ?
[Updated on: Tue, 02 December 2003 10:44]
gabe
Re: 4ac temp sensor question. help please!! Tue, 02 December 2003 10:50 Go to previous messageGo to next message
I want to make sure that my temp gauge is functioning correctly and I was going to make sure that the sensor is doing its thing first.
I am amazed at those tolerances though.....they are huge!!
Looks like I will have to pull the sensor out and bung it in the kettle......dang.
Scorpion
Re: 4ac temp sensor question. help please!! Tue, 02 December 2003 11:05 Go to previous messageGo to next message
The large tolerance is at the lower temperature end which is prety much irrelevant.
All this means is that to check if your sender is operating properly, next time you have your car up to normal running temperature with the radiator cap on, remove the wire from the temperature sender and measure the resistance between the sender terminal and earth. It should be between 24 and 27 ohms.
If your resistance measurement is less than 24 ohms you "might" have a problem.
gabe
Re: 4ac temp sensor question. help please!! Tue, 02 December 2003 11:11 Go to previous messageGo to next message
Sorry mate. Just reread your original post, those tolerances are much nicer......Thanks for the help.
Any idea what the sensor itself is made from?? I dont know of anything apart from carbon that has a negative temperature coeffecient. Just curious Rolling Eyes .
Scorpion
Re: 4ac temp sensor question. help please!! Tue, 02 December 2003 11:51 Go to previous message
No, no idea sorry. Confused
Previous Topic:Blue smoke and chewing oil
Next Topic:1g-gte power & injector flow rate
Current Time: Fri Oct 23 21:37:05 UTC 2026
Total time taken to generate the page: 0.022484064102173 seconds
