Toymods » Tech & Conversions » Diff Ratios
airfireman1
Perth WA
Diff Ratios Tue, 02 December 2003 11:33 Go to next message
Just finished putting a 5speed out of a 98 hilux 2wd into a YN57 previously auto 2wd hilux.
The speedo is out by about 10kph on the high side, does anyone know what the origional diff ratio would be and if it is worthwhile changing the ratios.
The old 3y has been dumped and a balanced 4y with a lot of headwork, cam change and a lot of expensive parts added. It is a very quick lux but could benefit with a bit taller diff.
How many 4y lux's can lay rubber in 3rd?
After ideas thanks
ra23celica
Re: Diff Ratios Wed, 03 December 2003 00:08 Go to previous messageGo to next message
Most likely that the original diff ratio was 4.9 and you are running 3.9 or 4.1 now, accounting for the large difference in speedo readings.
You should have no trouble hunting up a G series hilux diff and I have a spare 4.9 at home in Perth, West. Aust.
Mitch.
Re: Diff Ratios Wed, 03 December 2003 01:39 Go to previous messageGo to next message
If you just want your speedo to read incorrectly, changing the diff is a bit extreme! A more sensible approach is to change the speedo drive gears inside the gearbox, unless of course you have some other reason to change your diff ratio.
airfireman1
Perth WA
Re: Diff Ratios Wed, 03 December 2003 12:59 Go to previous messageGo to next message
Thanks Norbie, its just that its very quick thru the gears and an absolute blast off the lights but I feel that the top end speed will suffer a little. Hence i was looking at a slightly different ratio so I have the best of both worlds. Also mitch , just out of curiosity how much for the diff?
[Updated on: Wed, 03 December 2003 13:01]
knackers
berala sydney
Re: Diff Ratios Wed, 03 December 2003 17:51 Go to previous messageGo to next message
hi airfireman1
I have a g series heavy duty 4.555 diff centre if your interested.
cya knackers 0412106269
ra23celica
Re: Diff Ratios Wed, 03 December 2003 22:52 Go to previous messageGo to next message
$100 (my cost) but freight for this heavy thing out of Perth would make it uneconomic mate.
Mitch.
bubs
Jimboomba, Qld
Re: Diff Ratios Wed, 03 December 2003 23:07 Go to previous message
the hilux you pulled your gearbox from, runs a 3.7 ratio diff
Previous Topic:does anyone know how to put photos on
Next Topic:early MA61 out of tank fuel pump.
Current Time: Fri Nov 20 12:38:01 UTC 2026
Total time taken to generate the page: 0.0093629360198975 seconds
