Toymods » Tech & Conversions » Bumper cut/reinforcement for intercooler
wagonist
Toymods Club Treasurer
Bumper cut/reinforcement for intercooler Wed, 03 December 2003 03:19 Go to next message
I'm starting to organise fitting of a 7M intercooler into the front of my car.
Problem is that most of it will be blocked by the standard bumper which has a central piece the size of a Japanese number plate running up through the middle.
I want to remove this bit & relocate the number plate to the bottom of the bar.
How do I reinforce the opening now that its going to be full width?
Is there something I can put in there to give back some strength? I would prefer to stay away from the rice look with mesh. I also think the mesh would block a fair bit of airflow too which is critical for my radiator now that its going to have something else in the way.
http://www.caldina.ic24.net/graphics/caldina/9620fzdstevewandel120802/13may5.JPG
Re: Bumper cut/reinforcement for intercooler Wed, 03 December 2003 03:48 Go to previous messageGo to next message
Just jam a piece of steel/alloy bar in there and paint it silver/blue/whatever so it's not easily visible. It will be plenty strong enough and won't block much airflow.
wagonist
Re: Bumper cut/reinforcement for intercooler Wed, 03 December 2003 04:29 Go to previous messageGo to next message
Problem is I've already got the factory "cross" grills in that lower part on each side.
Probably would have to removed them too.
What would be the best way to secure the pieces to the bumper?
Classique71
Colac, Victoria
Re: Bumper cut/reinforcement for intercooler Wed, 03 December 2003 07:34 Go to previous messageGo to next message
what 3sgte do you plan to run in the caldina ?
if its the 205 motor - you shouldnt need to worry about frontmounting ..
Outherwise have a peek around for a more Open style bumper .
The person i met in brisbane was using a water to air intercooler setup i believe of some sort of subaru on his ..
not 100 % sure on this ..
i guess also with a top mounted W to A you may have clearance issues ?
wagonist
Re: Bumper cut/reinforcement for intercooler Wed, 03 December 2003 21:35 Go to previous message
I'm not going to putting that engine in, at least not for a long time. The budget doesn't allow it at this stage (The house is taking preference).
But in the meantime I want to take the turbo diesel as far as it will go.
Currently has no intercooler & is already running 12psi, which I want to increase to about 18.
The engine is setup backwards to the petrol ones.
ie exhaust is on firewall side with a highmount turbo & inlet manifold is on the front.
Previous Topic:20V vs 16V 100kw Strength Question
Next Topic:fuel....
Current Time: Fri Nov 20 14:11:20 UTC 2026
Total time taken to generate the page: 0.0051820278167725 seconds
