Toymods » Tech & Conversions » rims for front of sprinter
ae95
rims for front of sprinter Wed, 03 December 2003 05:27 Go to next message
Hey
What offset would a set of 16x7.5 's have to be to fit on the front of a sprinter?
CLG
Perth, Western Australia
Re: rims for front of sprinter Wed, 03 December 2003 06:19 Go to previous messageGo to next message
they'd still need an inset of around 3-7mm I'd assume. I have had several sets of 16x7's with insets of approx 14mm.
ae95
Re: rims for front of sprinter Wed, 03 December 2003 06:25 Go to previous messageGo to next message
so a 30+mm offset would be way out and hit the guards
CLG
Re: rims for front of sprinter Wed, 03 December 2003 06:28 Go to previous messageGo to next message
It depends on how the offset has been measured and defined, but I'd say that will hit the strut, not the guards - that is front wheel drive territory.
ae95
Re: rims for front of sprinter Thu, 04 December 2003 18:20 Go to previous messageGo to next message
would a 15x6 rim with a +40mm offset fit?
Sprinter
Re: rims for front of sprinter Thu, 04 December 2003 21:41 Go to previous messageGo to next message
+30 pos offset on a 7.5inch wide rim will foul the strut. I know I have tried. You only need about 5mm spacer to clear the strut. No problems on the rear tho.
Denis
Re: rims for front of sprinter Fri, 05 December 2003 02:49 Go to previous messageGo to next message
I know that 15x8's with an 8mm offset hit the inside of the wheel well at full lock, so you'd need less offset than that, prolly -8mm on an 8 inch rim. But then you may have the problem of hitting the guards on heavy breaking
ae95
Re: rims for front of sprinter Fri, 05 December 2003 05:41 Go to previous messageGo to next message
i just tried on the front and the wheel hits the strut JUST. with a 10mm spacer would it be alright or would the tyres rub.
i tried without any tyres on as that is how i got the rims.
Re: rims for front of sprinter Fri, 05 December 2003 05:45 Go to previous messageGo to next message
Depends on if you plan on getting tyres that are wider than the rims
CLG
Re: rims for front of sprinter Fri, 05 December 2003 05:52 Go to previous messageGo to next message
ae95 wrote on Fri, 05 December 2003 13:41
Have you thought about the lack of thread then available to the wheel nuts? Add the price of the spacers, eight long shank wheel studs, and the time to modify the hubs if you do it, or pay someone to do it?!!! Makes a cheap set of rims not so cheap hey?!?!
ae95
Re: rims for front of sprinter Fri, 05 December 2003 08:45 Go to previous messageGo to next message
ah yeah, ill try and find somethign else
ae95
Re: rims for front of sprinter Tue, 30 December 2003 08:11 Go to previous messageGo to next message
ok, 16x7.5 with a 10mm spacer would fit fine on the front of a sprinter?
wraith
Albany WA
Re: rims for front of sprinter Wed, 14 January 2004 06:33 Go to previous message
+38 16"x8", cut down to 16"x6.5" should mount a 205/45/ZR16 tyre with about 3mm clearance from the strut.
Previous Topic:wheres my fuel filter?
Next Topic:Got my supra and some probs...
Current Time: Sat Oct 17 11:33:28 UTC 2026
Total time taken to generate the page: 0.04926609992981 seconds
