Toymods » Tech & Conversions » Computer for 1G-gte
Aliencorolla
Computer for 1G-gte Wed, 03 December 2003 06:56 Go to next message
I am just wondering if any one has any recomendations for a aftermarket computer for a 1G-gte,it has a T4 hybrid on it,and the water to air cooler on top, its getting put into a MA61. I need an entry level computer, not big dollars like motec or haltech. Not after one that has boost controls just one that can get good power and will be reliable. i do want a hand controler so I can get good fuel economy. Also any one in melb that can do the wiring up for me. Thanks Clinton.
twinturbo86
Re: Computer for 1G-gte Wed, 03 December 2003 07:05 Go to previous messageGo to next message
the ems stinger is a pretty good system for the money ($995)
Re: Computer for 1G-gte Wed, 03 December 2003 09:09 Go to previous messageGo to next message
slightly OT but ...
i just stumbled over this on <www.lextreme.com>:
SparkDog: <http://homepages.ihug.com.au/~jharm/kit.htm>
i have no idea if its any good - but if you can build DIY electronics it might be value for $550. then you gotta redo a fair bit of wiring.
There's also the Megasquirt path, so you'ld have to dump the AFM to go MAP, dump the knock sensors (unless you keep the 1G computer to run spark), cold start and the aux air valve: <http://www.bgsoflex.com/megasquirt.html>.
charles.
Siktoy ra23
Plumpton/sydney
Re: Computer for 1G-gte Thu, 04 December 2003 11:58 Go to previous messageGo to next message
Go the EMS it works fine and drives like a Stock computer
Grant
Newcastle, NSW, Australia
Re: Computer for 1G-gte Thu, 04 December 2003 21:12 Go to previous messageGo to next message
Your first problem is your water/air IC. It will be far too restrictive for the turbo you have. Before looking into aftermarket, first spend your cash on a decent front-mount IC (or a custom water/air if your really set on it). If you already have the factory loom and ecu why not use it? I know a number of people who effectively use their factory ecu with a single turbo and then when money permits, install a decent aftermarket.
At the end of the day you get what you pay for. Don't scrimp on an aftermarket ecu; you will only regret it later. Oh, and a hand controller has nothing to do with economy. If that is your concern then stick to factory.
Siktoy, you'd have to be the first person I've ever heard of that was happy with an ems. Everyone else I know who has used one would gladly junk it in favor of something else. Personally I'd rather the limitations of a factory ecu any day over an ems.
[Updated on: Thu, 04 December 2003 21:47]
10sec_rx7
Syndey
Re: Computer for 1G-gte Thu, 04 December 2003 21:28 Go to previous messageGo to next message
you cant beat the microtech for valve for money,
for
$1500 i can supply, install and tune a LT8 for you, plus $90 per hour dyno hire,
with the correct tuning and install the microtech's drive the same as the factory ecu and will give better fuel economy,
Dale
dcving
newcastle nsw
Re: Computer for 1G-gte Fri, 05 December 2003 06:06 Go to previous messageGo to next message
i beg to differ Confused
10sec_rx7
Syndey
Re: Computer for 1G-gte Fri, 05 December 2003 11:05 Go to previous messageGo to next message
you beg to differ do you??
well you have tuned heaps of them and know what you are talking about then i take it...???
with the CORRECT tuning you will get better economy and a shit load more power, period....
when you can get 130km to $12 petrol in a 13b turbo with 2x550 and 4x 1200cc injectors come and talk to me...
Dale
[Updated on: Fri, 05 December 2003 11:08]
Aliencorolla
Re: Computer for 1G-gte Fri, 05 December 2003 11:10 Go to previous messageGo to next message
As I PMed to Grant the main reason i want after market comp is to stop the anoying cut out problem I had with it now and then, i thought I fixed it but it came back now and then. So I want to get somthing that will not have an air flow meter and the like.
dcving
newcastle nsw
Re: Computer for 1G-gte Sun, 07 December 2003 03:26 Go to previous messageGo to next message
i have a 1ggte with a microtech mtx8 and am getting less power than people with the same mods as me but running the standard comp, and yes it has been tuned by a very reputable microtech tuner, and yes this is on the same dyno on the same day.
so if you think you can tune my car with a shit load more power and better economy as you say you can, id be more than happy to pay for your tuning expertise.
so untill someone proves me wrong (as ive never seen or heard of anyone running microtech on their 1g) i cant recommend them, as ive had problems tuning mine, dont get me wrong as i know there worth their weight in gold running behind rotarys, as the magority of rotary owners are using them and the times and figires speak for themselves, as for 1gs im not convinced, and if i dont get anywhere near the power i should with my new engine setup i will be changing ecus to one i know ill get the sort of power i should be getting.
Danish
Re: Computer for 1G-gte Sun, 07 December 2003 03:48 Go to previous message
I also recomend a MicroTech, I have a LTX12 one on my 1JZ.
Previous Topic:Stroked
Next Topic:XT132 Corona brakes
Current Time: Thu Nov 19 09:44:28 UTC 2026
Total time taken to generate the page: 0.0054960250854492 seconds
