Toymods » The Outhouse » Fine or standard quality (DSC)?
Les
icon14.gif  Fine or standard quality (DSC)? Thu, 04 December 2003 06:16 Go to next message
With digital cameras, u have the option to take photos using the FINE or STANDARD setting
what are the differences?
the file sizes are halved in standard mode... i.e. bout 2mb for fine and 1 mb for standard ....
i cant the differences on the computer .. i am guessing when u print it out u can tell the difference ?
From http://search.dpreview.com/forums/search.asp?query =fine&forum=1002&fields=subject
The difference is the amount of compression used to store the picture. Normal will use a more aggresive algorithm resulting in a small jpg file but with more artifacts. Fine will result in a larger jpg due to less compression but with less artifacts. Printing a 4x5 or 4x6 will probably not show much of a difference but if you plan to blow up any of your shots, the artifacts will start to become more noticeable.
The uncompressed file sizes for both will be the same only the photo compressed in fine mode will be of a higher quality.
Found my answer dont worry - why did i post this on a car website ? Shocked
[Updated on: Thu, 04 December 2003 06:31]
jackel
Re: Fine or standard quality (DSC)? Thu, 04 December 2003 18:29 Go to previous messageGo to next message
Laughing
Re: Fine or standard quality (DSC)? Fri, 05 December 2003 00:27 Go to previous messageGo to next message
Zoom in heaps when you look at it on the computer and you'll see the quality difference,
We tested this out when we first got our now camera
Les
Re: Fine or standard quality (DSC)? Fri, 05 December 2003 01:42 Go to previous messageGo to next message
CrUZsida wrote on Fri, 05 December 2003 11:27
i did this with 2 similar pics taken INDOORS... could not see anything different at all......!
maybe if i take the photos outdoors when i zoom in i will see the differences ???
Re: Fine or standard quality (DSC)? Fri, 05 December 2003 01:52 Go to previous messageGo to next message
Nah, we did it indoors too
and the quality difference was visible at about 5000% zoom Razz
but outdoors should be more visible
Les
Re: Fine or standard quality (DSC)? Fri, 05 December 2003 02:29 Go to previous messageGo to next message
did u print out the photos by any chance ???
Re: Fine or standard quality (DSC)? Fri, 05 December 2003 02:37 Go to previous messageGo to next message
Les wrote on Fri, 05 December 2003 10:29
-ve
looking at them on a 6x4 print you will never be able to tell the difference
clubagreenie
1st street on the right
Re: Fine or standard quality (DSC)? Fri, 05 December 2003 12:23 Go to previous messageGo to next message
A std 6 x 4 is printed at photo lab at 300 dpi. So your if your pic is at 2400 x 1200 (2.88 megpxl) it's a larger than necessary file size and my sisiters biggest complaint at work. When you enlarge however that's when it makes a difference. Try to use tiff's if possible as there is no loss due to compression as there is with jpegs. had to work out the same deal with mine, high quality and super high are the same res but different compression rates. If you want to really large enlargements then you need to save in raws format and fine a lab with reguar fractal software. If you have a few days look it up and read away. Great new stuff but needs big computers and bigger dollars. But will take any raw image and enlarge without loss to extreme sizes.
Re: Fine or standard quality (DSC)? Fri, 05 December 2003 12:38 Go to previous messageGo to next message
clubagreenie wrote on Fri, 05 December 2003 20:23
So THATS the difference, the level of compression, aaaahhhhh, that makes soooo much more sense (I speaks goods engrish)
Thats CAG, you're a champ
clubagreenie
Re: Fine or standard quality (DSC)? Fri, 05 December 2003 22:59 Go to previous messageGo to next message
No Probs. If anyone wants info or prices let me know as my sis in law works at fletchers castle hill (next to cinemas). Will try to work a deal with her boss for discounts for us technologically minded and cashed up types. Also helps with finding out what everything means.
Edit of previous: EVERYTHING is printed at 300dpi (just to be clearer) but as you imagine you can only take a 2400 x 1200 so far before dropping res. Photoshop, image size adjustments, increasing that aparent res will actually deteriorate the quality and increase file size. Having said that you can push res but you will drop physical size to maintain res.
Example: 72 dpi 6 x 8 cm (240x180pxl) will go 300 dpi for photo qual prints and maintain file size but print size will become 2 x 1.5 cm. thats done with resample image off (maintains file size). If done with resample on then file size inreases to 2.15 meg (1000 x 750) but without serious software (thats where regular fractals comes in) image quality deteriorates as you cant add these extra pixles.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon1.gif  Re: Fine or standard quality (DSC)? Sun, 07 December 2003 23:55 Go to previous message
Les, take a photo of something at 45 degrees. Make sure there's lots of contrast between the object and the background.
You should be able to see more artefacts in the normal compression one.
FWIW, normal is fine for taking photos. It's only if you're anal about image quality (like me) or you're gonna do some graphics work with the photos that you'll want to use fine.
They correspond to the JPEG quality, ie: 75% or 95%...
Previous Topic:what to buy in Japan?
Next Topic:Sony memory stick 256meg how much in Aussie ?
Current Time: Thu Oct 15 11:03:48 UTC 2026
Total time taken to generate the page: 0.0051469802856445 seconds
