Toymods » Tech & Conversions » Fuel line recomendations
Siktoy ra23
Plumpton/sydney
icon5.gif  Fuel line recomendations Thu, 04 December 2003 11:48 Go to next message
Can anyone recomend what size fuel lines to run in my RA23 with a 1GGTE in it????
Re: Fuel line recomendations Thu, 04 December 2003 11:56 Go to previous messageGo to next message
Standard ones will be just fine.
Siktoy ra23
Plumpton/sydney
Re: Fuel line recomendations Thu, 04 December 2003 12:04 Go to previous messageGo to next message
Thanks norbs
I was hoping that was case,I am sick of working on this car Confused
CLG
Perth, Western Australia
Re: Fuel line recomendations Thu, 04 December 2003 12:46 Go to previous messageGo to next message
Yep standard 1/4" will do the job, however you will have to consider the fact they will be on the wrong side of the engine bay, and will need step down and up's for the efi line connections (efi is 5/16"). While changing the lines for the minscule 1/16" is going to some type of extreme, it also allows you to route the line to better suit the fuel rail, and avoid the step downs/ups that should be used to do the job prorerly.
Bundy tube is readily available from hose and tube supply shops, will only cost around $25 for a six metre length, and can be bent to any shape you want using a tube bender to avoid crimping the tube (this causes restriction problems, and will wear over time, internally). While you are buying the length, get the shop to flare both ends, you'll use one end, but will need to cut the line to suit on the other end. When you have the length cut to suit remove it and take it back to have the other end flared, and get the remaining end on the spare done too, you can use the off cut for surge tanks, or keep it as a handy spare length.
All in all, overkill for your application, but results in a cleaner effect.
Bugman
Re: Fuel line recomendations Sat, 06 December 2003 03:23 Go to previous message
No Message Body
Previous Topic:ST-185 Torque Settings
Next Topic:what problems to look for in a 3t-gte
Current Time: Thu Nov 19 22:11:19 UTC 2026
Total time taken to generate the page: 0.0057299137115479 seconds
