Classifieds » Parts Wanted » TA23 or similar ignition barrel wanted
Alchemist
icon1.gif  TA23 or similar ignition barrel wanted Fri, 05 December 2003 02:24 Go to next message
Hi guys,
Having problems getting my car started, ignition barrel seems to have some bad conenctions happening so its time to change it. I was wondering if the ignition barrel from any TA2X or RA2X would fit. Other question is(this is my lack of technical knowledge), if I change the ignition barrel will I then need a different key to get my car started, or is the barrel behind the locking mechanism?
Thanks,
Alchemist
*edit* if you live in Sydney, and have one of these suckers and want to make some extra $$$ or beer and help me change the bastard over I'm quite open to that Smile Gotta learn sometime...
[Updated on: Fri, 05 December 2003 02:25]
sleeka73
Re: TA23 or similar ignition barrel wanted Fri, 05 December 2003 04:14 Go to previous messageGo to next message
its not the actual barrel which has the connections in it , its the housing behind it that does
CLG
Perth, Western Australia
Re: TA23 or similar ignition barrel wanted Fri, 05 December 2003 05:34 Go to previous messageGo to next message
Yep, I have one complete here. I can either supply it with barrel and key, or bare so you can put your barrel into it, and can give you instructions for removal and refit if needed. Will PM you some details.
By the way, TA22 barrels and houdings are different and won't fit the later models.
roadrunner
Hornsby, Sydney
Re: TA23 or similar ignition barrel wanted Sun, 07 December 2003 06:33 Go to previous message
I got A good barrel and switch if you want it.
Previous Topic:ta22 drivers side window
Next Topic:AE82 rear drums needed
Current Time: Sat Nov 21 14:25:04 UTC 2026
Total time taken to generate the page: 0.0098738670349121 seconds
