Toymods » Tech & Conversions » Mk3 Supra Brake upgrade
trza2k
Mk3 Supra Brake upgrade Fri, 05 December 2003 05:58 Go to next message
Was looking at getting a brake kit from the states for a MA70 supra, the price was pretty good but they use wilwood calipers for the kit which i was told cannot be engineered in Australia for road use as they dont have dust covers (and other things i cant remember?). So ruled this option out.
Found another option that requires a bit of this and that to fit, some z32 calipers + supra mk4 rotors to the ma70 supra. Have a look at http://www.70supra.com/supra-diy/caliper/caliper.h tm , best to use http://world.altavista.com to convert the URL from japanese to english. Only concern here is the grinding of 5mm off the hub mount and the other bits they do, dont know if this will be allowed to be engineered. But the kit costs about $500 which is for the 2x special brackets, 2x offset spacers and chromolly bolts, Then of course i would need the calipers+rotors.
So just wondering is either of the options 'engineerable' or is there any other cheap options for a brake upgrade for ma70.
Thanks.
[Updated on: Fri, 05 December 2003 08:36]
supra1jz
Launceston, Tasmania
Re: Mk3 Supra Brake upgrade Fri, 05 December 2003 08:51 Go to previous messageGo to next message
If you want bigger rotors just buy the jza70 rotors they're 300+mm. If you want something better go to Specialised Brake and Clutch in St marys (Sydney). I have custom mounting hats and slotted rotors 330mmx28mm for $450 each side that's hat and rotor. I've been told Wilwood's are not good for heavier cars and you're better off going with AP's Brembo's or Alcon etc. These are not THAT expensive when you consider what we all pay for extra engine performance e.g. the top of the range monoblock 6 piston alcon is $1350 per caliper and it's f*ckin huge!!!!! Personally I don't think this is too bad and obviously 4 spotters are a lot cheaper.
V8_MA61
Re: Mk3 Supra Brake upgrade Fri, 05 December 2003 10:20 Go to previous messageGo to next message
why do you want to go bigger than the ma70 brakes? They're massive and excellent from factory! What are you planning to do with the car? Im planning on doing an ma70 brake conversion if yours are for sale...
trza2k
Re: Mk3 Supra Brake upgrade Fri, 05 December 2003 10:59 Go to previous messageGo to next message
supra1jz wrote on Fri, 05 December 2003 19:51
Already have 300mm slotted dba's.
Rang up brake and clutch last week (saw a old thread mention the name) and price was $2900 for a AP Racing 4pot caliper and 330mm rotors with custom hats for the front. If i do the z32 way i can get 324mm rotors with the 4 piston, but it will cost $500+$300 calipers+$400 slotted rotors which works out quite a bit cheaper, but dunno how engineerable it is with the shaving spacers+shaving of the hub.
mk3 Supra brakes are resonabley big, but the car is damn heavy and the caliper is single piston. They do stop "ok" but repeat several times and watch them fade Razz . Thats why going the bigger rotor/4piston will help that *hopefully*
7M-Brisbane
Re: Mk3 Supra Brake upgrade Fri, 05 December 2003 11:02 Go to previous messageGo to next message
Um yeah.. MA70's have 300mm rotors stock...
lumpy
Adelaide, SA
Re: Mk3 Supra Brake upgrade Fri, 05 December 2003 11:24 Go to previous messageGo to next message
7M-Brisbane wrote on Fri, 05 December 2003 21:32
Yeah - what he said! Razz
I've heard some people say that some MA70 brakes are different to others, but mine were exactly the same size as the JZA-70 ones. Perhaps the GA70 ones were smaller?
Got brake fade? What pads are you using? I'm gone to EBC Greenstuff and have no problems with fade even after some seriously hard driving (ie smoking brakes and glowing rotors) Very Happy Very Happy
Allan
Re: Mk3 Supra Brake upgrade Fri, 05 December 2003 16:44 Go to previous messageGo to next message
GA70 and some MA70's (that come with 15 inch wheels) have smaller brakes
7M-Brisbane
Re: Mk3 Supra Brake upgrade Sat, 06 December 2003 03:25 Go to previous messageGo to next message
I think you'll find that's a rumour more than anything.
There is always a chance, but I find it unlikely.
I have seen numerous (australian and import) MA70's and am yet to see one with brakes <300mm.
In addition to that, I had an unmodified GA70 half cut which had 300mm brakes on it.
I think you'll find that certain (not all) 15" wheels fit over the 300mm brakes.
Allan
Re: Mk3 Supra Brake upgrade Sat, 06 December 2003 12:31 Go to previous messageGo to next message
7M-Brisbane wrote on Sat, 06 December 2003 14:25
Richard (supra78) has two MA70's one big, one small brakes both stock
Allan
bbaacchhyy
Re: Mk3 Supra Brake upgrade Sun, 07 December 2003 22:55 Go to previous messageGo to next message
According to the DBA catalog, there are three sizes of rotors listed ;
Supra 1/86 to 5/93 MA70/71 - DBA715 - 300mm dia x 22mmm thick
Supra 5/93 on MA non turbo - DBA712 - 296mm dia x 32mmm thick
Supra 5/93 on MA turbo - DBA718A/B - 323mm dia x 30mmm thick
They are listeds as MA's, but I guess the last two (5/93 on) are the JZA80 ? Confused
Michael B
7mgtema71
Re: Mk3 Supra Brake upgrade Sun, 07 December 2003 23:22 Go to previous messageGo to next message
The JZ80's came with two different brakes setups. One for turbo and one for NA. You could've opted for the turbo brakes on your NA though.
I'm not sure what brakes pads i have on my MA70, but i went for a burn round the local hills the other night and it never hesitated on the brakes (very supprised). A friend of mine has better pads on his MA70 and it handled the same, never faded once. But his brother apparentle has fadded after a few sudden stops.
Just my two cents...
trza2k
Re: Mk3 Supra Brake upgrade Sun, 07 December 2003 23:31 Go to previous messageGo to next message
When i bought my mk3 supra it actually only had 275mm rotors on it, but i think this was more a ghetto rotor change as the brake pad wasnt even getting full contact on the rotor.
Ive now got bendix metals + dba rotors on the ma70 might do some more testing on the fade.
SupraPete
Re: Mk3 Supra Brake upgrade Mon, 08 December 2003 02:12 Go to previous messageGo to next message
I upgraded my standard MA70 (Turbo) disks for JZA70 ones. Bigger and slotted. Also put in a set of EBC green stuff pads.
A very good option for upgrading, and on the track it was my tyres that were fading before my brakes.
Re: Mk3 Supra Brake upgrade Mon, 08 December 2003 02:40 Go to previous messageGo to next message
I have seen GA70, MA70 and JZA70 rotors side by side and they were all identical. None of them were slotted either!
SupraPete
Re: Mk3 Supra Brake upgrade Mon, 08 December 2003 02:50 Go to previous message
I bought them through here for $75 and they were a direct bolt on.
Something had to be used from the old disks but I can't remember what. I got the toymods sponsor to do it.
Previous Topic:FYI - 20v 4age rebuild parts now available!!
Next Topic:Starting issues, TA23 -Ignition barrel-
Current Time: Sun Nov 1 23:15:42 UTC 2026
Total time taken to generate the page: 0.0079870223999023 seconds
