Classifieds » Miscellaneous » w58 gearbox : ex ma-61
ed_ma61
Lost in the K hole
w58 gearbox : ex ma-61 Sat, 06 December 2003 10:12 Go to next message
w58 gearbox
ma61 supra shifter position
note: needs new shifter bushes (which i can get and install for sale (extra $35))
otherwise, zero bearing noises, and no leaks whatsoever. 2nd and 3rd syncros are a little rough, but no more than youd expect on a 20 year old box.
$350
Exceedy HHD clutch, flywheel, bellhousing etc all available inseparate posts...
all in sydney
can deliver for cost of petrol Smile
ed
TE72_Turbo
Re: w58 gearbox : ex ma-61 Sun, 07 December 2003 10:05 Go to previous messageGo to next message
Hey Ed, I know its a hassle, but would you be prepared to separate the shifter housing & stick if there's not much interest in the box? It is the 20" shifter position on the MA61 isn't it? Confused
Phil
ed_ma61
Lost in the K hole
Re: w58 gearbox : ex ma-61 Sun, 07 December 2003 10:24 Go to previous messageGo to next message
yeah, sure, if i dont sell it ill look at pulling it out.
but to be honest, i hope it doesnt come to that Razz
ed
TE72_Turbo
Re: w58 gearbox : ex ma-61 Sun, 07 December 2003 11:25 Go to previous messageGo to next message
After a quick inspection of my box, it seems that its not such a simple swap for the shifter position anyway. Looks like the cast steel linkage that connects the gearstick to the actuator rod needs to be exchanged also, which means the rod has to be removed from its position in the box.... maybe i'll just hack my trans tunnel after all. Mad
Please tell me i'm wrong and its just a simple swap! Confused
Phil
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: w58 gearbox : ex ma-61 Sun, 07 December 2003 15:07 Go to previous messageGo to next message
The rod doesn't have to be removed, but the extension housing does. So the box has to be out of the car, so if it is atm, now's the best time to do it.
ed_ma61
Lost in the K hole
Re: w58 gearbox : ex ma-61 Sun, 07 December 2003 23:39 Go to previous messageGo to next message
errr, actually joel, the shift selector fork does probably have to come out... id be betting that the shift selector yoke that sits on the shaft is different (to accomodate the different housing/pivot position).
you need to do this on mkiv-mkii housing swaps, and id imagine this would be very similar
BigWorm
Turramurra, Sydney.
Re: w58 gearbox : ex ma-61 Mon, 08 December 2003 01:03 Go to previous messageGo to next message
I know you have to change the yoke thing that sits on the shaft, but I was under the impression that that just required the rear extension housing to be unbolted & slid back a few inches, just enough to slide the old yoke off & the new one on.
It'd better not be much harder than that, I'm gonna be doing it soon! Smile
ed_ma61
Lost in the K hole
Re: w58 gearbox : ex ma-61 Mon, 08 December 2003 01:07 Go to previous messageGo to next message
yeah, as long as the selector yoke actually bolts into the same hole on the shaft as the original one... otherwise, the shaft has to come out, and you have to drill and tap a new mounting hole in the shaft...
and the difference between 'sliding back' and totally disassembled rear housing is only a few mm anyway!
BigWorm
Turramurra, Sydney.
Re: w58 gearbox : ex ma-61 Mon, 08 December 2003 01:21 Go to previous messageGo to next message
Oooh, shit hey, I hope I don't have to go through that with mine.....
Yeah, but sliding it back a few inches sounds so much easier than totally disassembling. Smile
Re: w58 gearbox : ex ma-61 Mon, 08 December 2003 05:34 Go to previous messageGo to next message
Nah, that little keyhole is the same
All you need to change it is the top bit that the shifter bolts into, and the bottom bit that the base of the shifter sits in
I know, I done twice (its the same on a w40-50 swap too)
TE72_Turbo
Re: w58 gearbox : ex ma-61 Mon, 08 December 2003 09:14 Go to previous messageGo to next message
Good! So it is just a matter of sliding back the rear housing then? Smile
ed_ma61
Lost in the K hole
Re: w58 gearbox : ex ma-61 Mon, 08 December 2003 09:48 Go to previous messageGo to next message
yep Nod
honestly, 'sliding the rear housing back' is literally mm's from 'rear housing comes off'...
anyway...
w58 for sale...
TE72_Turbo
Re: w58 gearbox : ex ma-61 Mon, 08 December 2003 11:20 Go to previous messageGo to next message
yeah, well it will be coming right off anyway, to change the gasket.
BigWorm
Turramurra, Sydney.
Re: w58 gearbox : ex ma-61 Mon, 08 December 2003 14:27 Go to previous messageGo to next message
Doh, that's a good point.
ed_ma61
Lost in the K hole
Re: w58 gearbox : ex ma-61 Tue, 09 December 2003 01:06 Go to previous messageGo to next message
there is no gasket... silicone my friend...
ahem...
w58 for sale...
ed_ma61
Lost in the K hole
Re: w58 gearbox : ex ma-61 Tue, 09 December 2003 10:52 Go to previous messageGo to next message
open to offers Nod
TE72_Turbo
Re: w58 gearbox : ex ma-61 Tue, 09 December 2003 11:58 Go to previous messageGo to next message
strange, mine appears to have paper gaskets, you can see the tags sticking out...
ed_ma61
Lost in the K hole
Re: w58 gearbox : ex ma-61 Tue, 09 December 2003 12:03 Go to previous messageGo to next message
well, my mkiv box (which i can garuntee had never been pulled down) was only assembled with silicone, or 3 bond, or wtf they use...
go figure...
w58 still for sale
Laughing
TE72_Turbo
Re: w58 gearbox : ex ma-61 Tue, 09 December 2003 12:26 Go to previous messageGo to next message
hmmmm, mine is an older W55 from an RT133 corona though. Confused
let me save you the hassle:
w58 still for sale
consider it a bonus bump Razz [sorry for the hijack Smile ]
[Updated on: Sat, 07 February 2004 08:07]
bbaacchhyy
Re: w58 gearbox : ex ma-61 Thu, 11 December 2003 21:20 Go to previous message
pm sent
Previous Topic:WANTED GTi COROLLA FRONT SEATS IN G/C
Next Topic:body kit
Current Time: Sun Oct 25 03:59:18 UTC 2026
Total time taken to generate the page: 0.0061578750610352 seconds
