Toymods » Tech & Conversions » Need help with my 86
Instigator_PsY
Melbourne Victoria
Need help with my 86 Sat, 06 December 2003 23:53 Go to next message
Hi guys this is my first post.
I just bought my 1985 corolla gts, i need some help with getting my car to roadworthy (I'm in melbourne).
Firstly i discovered an exhaust leak at a joint after the CAT i haven't yet jacked the car up but I'm sure i this would be easily fixed (would this problem cause the engine light to come on?).
The 1 of the wheel mount struts bolts,whatever you call em from each side of the front are cut off, the front wheels are in held by 3 lug nuts, what will i need to by to fix this.
OK another problem I'm having is that I'm able to shift into gears without disengaging the clutch, after i noticed this problem i didn't try and drive it. I'm new with cars i read a few techs you guys have on this forum but i cant seem to find what the problem could be. (BTW its a trd short shifter)
Well they're the 3 main problems i got right now, also would to get a RWC in Victoria can a car have a roll cage? (the dash hasn't been cut nor has any of the chassis, it's a bolt on) another thing....The front panels sides are being supported with wires (just the sides).
Thank you guys.
Daniel Chatenfeld
[Updated on: Sat, 06 December 2003 23:54]
shinybluesteel
melbourne
Re: Need help with my 86 Sun, 07 December 2003 01:25 Go to previous messageGo to next message
first of all, its not called a gts here, (unless your car is an imported/converted american model) that is a yankieland term AFAIK, club4AG is an american based site.
as for the wheel studs, you can replace these yourself, but getting a mechanic to do it would be easier, they need to be hammered out and replaced, i think it is a fairly straight forward job.
the shifting into gears without using the clutch isnt a problem, i can do that when i wan to, just use the clutch more often.
NFI about the cage,
good luck
Instigator_PsY
Melbourne Victoria
Re: Need help with my 86 Sun, 07 December 2003 01:42 Go to previous messageGo to next message
thx, could you give me a price estimate for the studs and the gaskets for the exhaust.
Thnx
Necros
Re: Need help with my 86 Sun, 07 December 2003 09:55 Go to previous messageGo to next message
Just take the car to your local mechanic... They will be able to fix the problems and give you a RWC!
Also it is not illegal/unroadworthy to have a roll cage in a car. But there are guidelines which are listed on the vicroads website... www.vicroads.gov.au
ae86drift
sydney.au
Re: Need help with my 86 Sun, 07 December 2003 10:06 Go to previous messageGo to next message
i had a half cage. they wouldnt let me keep it in the car AND have rear seat. t was either the back seat OR the cage. if its a fullcage, then it needs to be padded where the people come in contact with the cage (30cm movement room from belted seating position).
see image below
http://www.j-spec.com.au/garth/147%20(35).jpg
gaskets for exhaust should be about 30 bucks from repco/toyota Smile
Instigator_PsY
Melbourne Victoria
Re: Need help with my 86 Sun, 07 December 2003 11:07 Go to previous message
Ah thnx guys, my cage is half cage and its allready padded plus my rear seats are out.
Previous Topic:1JZ boost raise
Next Topic:hi flowing a CT26 for a SW20
Current Time: Sun Nov 22 23:30:21 UTC 2026
Total time taken to generate the page: 0.18717288970947 seconds
