Toymods » Tech & Conversions » 18rc head onto 18rgu block
people100
Rocklea qld
18rc head onto 18rgu block Sun, 07 December 2003 03:19 Go to next message
Ive got a spare 18rgu block that i was using for parts and was just wondering if i could put an 18rc head onto it just for something to do. Would it make it higher compression then a standard 18rc engine or would it be worse. Is it possible as i have all the bits here doing nothing. Any help appreciated
CLG
Perth, Western Australia
Re: 18rc head onto 18rgu block Sun, 07 December 2003 04:37 Go to previous messageGo to next message
Blocks are the same between the two, pistons are different, along with other sundry items (top timing chain, oil pump, timing chain covers, ...). You may run into valve/piston interference problems- this is where the plasticine comes in handy to check for clearance!
people100
Rocklea qld
Re: 18rc head onto 18rgu block Sun, 07 December 2003 05:15 Go to previous messageGo to next message
the difference in pistons is the 18rgu pistons are domed on top arent they. so basically if i put an 18rc head on there with be less room in the chamber so higher compression wouldnt there?
Re: 18rc head onto 18rgu block Sun, 07 December 2003 06:14 Go to previous messageGo to next message
from memory, the 18R chamber in the head does not cover the entire piston area - i think there are a few tight squish areas away from the valves - so do some measuring before bolting head to block.
Even if piston/head don't hit, using uneven squish areas to lift compression ratio tends to increase detonation/pinging.
also, the whole front of the engine is different - timing cover, timing chains, dummy (half shft) to run dizzi & oil pump, water pump, etc are different between 18RG and 18RC
Would be easier/safer/cheaper to find an 18RG head, give it a quick-and-dirty reco and bolt it up. You'll get better breathing, cooling, power etc than the 18R.
charles.
people100
Rocklea qld
Re: 18rc head onto 18rgu block Sun, 07 December 2003 10:07 Go to previous messageGo to next message
Did really wanna spend money on it. was just gonna fix it up and hope maybe it had better compression and put it in my fathers car as he only has a crappy 2s-c in a sa63 celica.
Re: 18rc head onto 18rgu block Sun, 07 December 2003 10:23 Go to previous messageGo to next message
What makes you think an 18R-C is going to be any better than a 2S-C?
people100
Rocklea qld
Re: 18rc head onto 18rgu block Sun, 07 December 2003 10:36 Go to previous messageGo to next message
anything has got to be better then the crappy 2s engine he has in it.
Re: 18rc head onto 18rgu block Sun, 07 December 2003 10:42 Go to previous messageGo to next message
Clearly you don't have much experience with 18R-C's. Laughing
Jason
Re: 18rc head onto 18rgu block Mon, 08 December 2003 00:53 Go to previous messageGo to next message
two words
"BOAT ANCHOR"
people100
Rocklea qld
Re: 18rc head onto 18rgu block Mon, 08 December 2003 07:21 Go to previous messageGo to next message
I was only condiering it as just a project for something to do if it would give me higher comp then a standard 18rc.
Re: 18rc head onto 18rgu block Mon, 08 December 2003 07:39 Go to previous messageGo to next message
If anything the 2S-C is probably better than the 18R-C...its just no one is silly enough to waste money on them! Smile
Allan
Re: 18rc head onto 18rgu block Mon, 08 December 2003 13:15 Go to previous messageGo to next message
Jason wrote on Mon, 08 December 2003 11:53
two words
"BOAT ANCHOR"
Nup to heavy for one man to lift and throw overboard!
Re: 18rc head onto 18rgu block Mon, 08 December 2003 23:05 Go to previous message
almost too heavy for TWO men to lift and throw overboard - although that IS what should be done to them.
Darn 18R-C's.
Previous Topic:4AGZE BIG PORT HEAD WHAT MODEL CAME OUT WITH THAT HEAD?
Next Topic:new diff
Current Time: Sat Oct 31 16:41:41 UTC 2026
Total time taken to generate the page: 0.11455988883972 seconds
