Toymods » Tech & Conversions » 20v starter relay
neat 20valve
20v starter relay Sun, 07 December 2003 05:54 Go to next message
does anyone know where the black with white strip wire coming out of the starter relay is ment to go, it looks like this has to be conected to something for the motor to run, if i connect it to my oil guage wire the motor will run, but the starter motor will not disenguage. any thoughts
DAMO
MELBOURNE
Re: 20v starter relay Sun, 07 December 2003 10:40 Go to previous messageGo to next message
dont know what you mean about starter relay but that wire usually comes from the start position on your ignition switch and goes to the solenoid on your starter which in turn when energised puts power from your battery to starter motor. hope this makes sense
sideshow
Re: 20v starter relay Sun, 07 December 2003 11:31 Go to previous messageGo to next message
yer the black with white trace should egt power from stasrt signal on ignition barrel
then the thick black one on hte starter relay should goto the starter solenoid
neat 20valve
Re: 20v starter relay Mon, 08 December 2003 22:25 Go to previous messageGo to next message
i know what u boys are saying and your both right but i think its got to do with something else, not the starter as such but more like electric side of things, like a signal to tel the computer the car has started and to go about its buisness.
i can start the car with out this wire hooked up, but it will only run for about 3 seconds or less if i touch the gas,
but will run if i hook it up to the oil signal line, that is what makes me think it is looking for a signal from something.
regards Craig
jasonp1977
Re: 20v starter relay Tue, 09 December 2003 02:05 Go to previous messageGo to next message
have you got the start feed connected to pin N2 on the ECU? the STA terminal?
neat 20valve
Re: 20v starter relay Tue, 09 December 2003 03:23 Go to previous messageGo to next message
There is a wire there but maybe its not hooked up at the other end. i will have a look, thanks
sideshow
Re: 20v starter relay Tue, 09 December 2003 08:57 Go to previous messageGo to next message
the sta feed to ecu does fuk all except bit more fuel maybe
doesnt stop car from runnin
i garantee u have not hooked up the trigger for the fuel pu,mp relay also know as circuit openin relay
it comes from the air flow
when the airflow opens it triggers the fuel pump relay
this wire is green/red trace
it runs from the airflow to the big grey plug neaer the ecu plugs
if this is wired in then check that the fuel pump works when u open the airflow flap by hand with ignition on
what is happenin is when u crank its triggering the fuel pupmpo relay to run the pump but then when u goto ignition it relies on the airflow to keep pump relay go9in and thats y it runs for 3 secs
[Updated on: Tue, 09 December 2003 09:02]
neat 20valve
Re: 20v starter relay Tue, 09 December 2003 20:26 Go to previous message
i think u may be right there, now i just have to wire it up,
thanks for all your help guys.
regards Craig
Previous Topic:Maximum power output of a 4agze/4agte?
Next Topic:headlight conversion TA22
Current Time: Mon Nov 2 02:31:22 UTC 2026
Total time taken to generate the page: 0.0051949024200439 seconds
