Toymods » Tech & Conversions » 7MGE, 1JZGE or 2JZGE
7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 00:38 Go to next message
I've got a friend whose looking at replacing the 5mge in his Cressida.
Whats a better bang for buck swap here?
A 7mge eng,loom,box for about 1000
1jzge for 1500
2jzge for 2000
These are about the avg prices in Perth, I could get the down lower but I'm just looking for a comparison here.
Any info is appretiated
Later
ed_ma61
Lost in the K hole
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 00:44 Go to previous messageGo to next message
1jzge gutless, so dump it from the start
7m = $1k
2jz = $2k
7m + $1k = 2jz
depends what he wants out of a motor...
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 00:47 Go to previous messageGo to next message
Thanks Ed
I had a feeling that the 1jzge we gutless, but I wasnt sure
He just wants to replace the 5m with something with a bit more power and reliability, but doesnt want to go all out with a 1uz, or a turbo conversion.
I'll keep searching around for a 2jzge cut for him (or a cheap 7m)
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 00:48 Go to previous messageGo to next message
Immediately scrap the 1JZGE - immediately you have all the grief of changing mounts and wiring for zero performance gain over a 7MGE.
The 7MGE bolts in but you will have wiring issues. I'd replace the head gasket as part of preventative maintenance. However it would be a straight forward conversion and a good upgrade from the 5MGE.
My choice would be the 2JZGE....but I'm biased. If I were on a budget, I'd go the 7MGE.
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 00:55 Go to previous messageGo to next message
Yeah, 2j would be my personal choice too
Any idea if that MA61 JZ mounts would suit a Cressida?? How much were they??
I'll try and search around and get one for $1500.
It should be too hard
ed_ma61
Lost in the K hole
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 00:57 Go to previous messageGo to next message
ma61 uses forward mounting position and front sump... cressida has mid mounting position and mid sump (i think!)
thus i doubt ma61 mounts would work in a cressy
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 01:19 Go to previous messageGo to next message
I was under the impression that a Cressida uses a front sump? I know mine does Razz
Anyway Ed, if we go 7M, take AS MUCH meat off the head as possible while keeping it non-interference (or what-ever the term is Razz, damn mental block), MHG (if required) ARP bolts, what costs, power increases would be expected?
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 01:49 Go to previous messageGo to next message
You pretty much described an engine rebuild there, so costs will be similar to doing a 2JZ conversion. I know what I'd be doing for the same money!
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 01:51 Go to previous messageGo to next message
So a stock 2jzge would make more power and be happier than the above mentioned modifications on a 7m?
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 02:00 Go to previous messageGo to next message
Yes, definitely.
ed_ma61
Lost in the K hole
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 02:45 Go to previous messageGo to next message
ohhh, i dunno norbs...
you spend $1k on a 7mge, and youd have a pretty fair contestant to a 2jzge, plus you have the advantage of her being opened up, and several items replaced and new - you have a better baseline to then work from.
my 2c
ed
ed_ma61
Lost in the K hole
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 02:47 Go to previous messageGo to next message
this is assuming the bottom end is in good nick
2jzge would obviously be newer, and odds of b/e being in good nick would be better.
me: id choose a 2jz over a 7m - only cause id work its tits off, and if i were to do that, i may as well start from the higher platform...
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:03 Go to previous messageGo to next message
Yes you could pull your 7M apart and spend a grand on it, or you could just buy a 2JZ and install it without having to touch a thing. Me being the lazy bastard that I am, the latter option is always going to win! Why make things more complicated than they have to be?
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:05 Go to previous messageGo to next message
Norbie wrote on Mon, 08 December 2003 11:03
This coming from a guy who decided to make his auto 2jzgte a manual, and change the fluid clutch fan to a normal one
Yes, less worth there Norbie, heaps less
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:06 Go to previous messageGo to next message
Hehe, and the fact that pretty much anything you can do to a 7M to improve its performance you could do to a 2JZGE which was better to begin with.
ed_ma61
Lost in the K hole
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:13 Go to previous messageGo to next message
yep, what nathan said, but consider the fact that the 7m is cheaper to start with - gives it a head start...
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:17 Go to previous messageGo to next message
ed_ma61 wrote on Mon, 08 December 2003 11:13
It will prolly need it in a drag too!
CrUZsida wrote on Mon, 08 December 2003 13:05
Actually both those things were the easier option! Keeping the auto would have required transmission tunnel mods and a strange custom tailshaft with rubber bits in it. Keeping the fluid fan would have been all manner of dramas with hydraulic lines, reservoirs and coolers, not to mention the fact it just plain wouldn't fit!
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:19 Go to previous messageGo to next message
Ah, yes, but what Norbie did is truly lazy. He set it all up so that there is a minimal degree of fuss later on. Very Happy No need to set up the pesky hydraulic pump (or wacky modifications to make it work), no heavy autos to lift in and out when they fail - I like his style. Now he can just wander off to any parts store and ask for an off the shelf item.
Really, it's an either or proposition. However, I'd dare say, you'd be hard pressed to get a 7MGE in 'good' condition.
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:21 Go to previous messageGo to next message
I doubt putting 400hp through a w58 will require minimal fuss later on
But time will tell on that front
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:30 Go to previous messageGo to next message
The 2JZGE W58 has sat behind 600hp NA-T Mk4 Supras with no issues. Plenty of anecdotal experience on Supraforums to suggest that they right up to the task.
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:32 Go to previous messageGo to next message
1UZ-FTE?
EDIT - AKA: Jamie?
[Updated on: Mon, 08 December 2003 03:43]
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:49 Go to previous messageGo to next message
No. The yanks have built quite a few turboed 2JZGEs. As always, some just have to be silly about it and produce insane numbers. A couple of the guys (Dave H - 680+ hp, Ethan Banks - 980 hp just to name a few) are running W58 boxes and have not had any grief.
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:55 Go to previous messageGo to next message
I was suggesting that hasnt Jamie broken 2 mk2 w58s, and 1 mk4 w58 behind his UZ?
These are reports that I have heard second hand
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 03:57 Go to previous messageGo to next message
Let's not forget my W58 has been coping behind the 2JZ since before Easter, and as the Supra is currently my only working car it's had plenty of use (and abuse) since then, including several runs at the drags, a return trip to Melbourne, and a return trip to Sydney! If the W58 was going to cause problems I think I'd know about it by now...
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 04:16 Go to previous messageGo to next message
Hmmm, good point Norbs, I had forgotten it has been in so long
But we have gone waaaaay OT here
But I think I have my answer anyway
2JZGE if we can find a cheaper one
7MGE if we can't
Cheers Lads
Allan
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 04:35 Go to previous messageGo to next message
Norbie wrote on Mon, 08 December 2003 14:17
I find that hard to beleave seeing the size of the autos have hardly changed! and the tailshaft issue is easy fixed in many ways!
Allan
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 04:37 Go to previous messageGo to next message
The transmission fits no worries, but the big stupid rubber thing on the front of the tailshaft doesn't. Sad
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 04:44 Go to previous messageGo to next message
Don't you hate it when the rubber thing doesn't fit the tailshaft?
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 05:30 Go to previous messageGo to next message
Yes, it's embarassing! Embarassed
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 07:05 Go to previous messageGo to next message
CrUZsida wrote on Mon, 08 December 2003 11:55
Nope, Jamie has destroyed one old-style W58, although he suspects this may have had some damage from neglect with oil previously. He now has a 2JZGE W58 and its holding up fine.
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 07:09 Go to previous messageGo to next message
Ah, kool
I'd heard it was a few more than that
Re: 7MGE, 1JZGE or 2JZGE Mon, 08 December 2003 07:10 Go to previous message
Thats what people said but I asked him Smile
Previous Topic:Fuel Pump - 2TGEU
Next Topic:Where are the indicator wires in a starlet?
Current Time: Sat Oct 31 21:08:56 UTC 2026
Total time taken to generate the page: 0.0072369575500488 seconds
