Toymods » Tech & Conversions » Fouling spark plugs
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon5.gif  Fouling spark plugs Mon, 08 December 2003 00:51 Go to next message
Hey guys,
I had fouled spark plugs so I bought a new set. I found out later that I'd bought the wrong heat range. 5 instead of 6. Anyway, they've fouled up. I suspect that it happened after the couple of hot days that we had a little while ago. The temps were in the mid 30s I think and I was thrashing the car around. It got pretty damn hot... Could it be the combination of wrong heat range and my notoriously overheating engine?
Or could it be the oxy sensor?
[Edit: Me kant speel]
[Updated on: Mon, 08 December 2003 02:54]
ed_ma61
Lost in the K hole
Re: Fouling spark plugs Mon, 08 December 2003 00:55 Go to previous messageGo to next message
having the colder heat range (5) means the plug wont get hot enough to burn off the slugde it collects - and they foul... this may have caused the problem you describe with the plugs you just put in...
faulksy
Re: Fouling spark plugs Mon, 08 December 2003 01:30 Go to previous messageGo to next message
could be a combination of running hot and lean.
Nark
Cabramatta, NSW
icon7.gif  Re: Fouling spark plugs Mon, 08 December 2003 02:59 Go to previous messageGo to next message
Kewlies. Good to hear. I just wanted to know before I put a new set of spark plugs in... It's a huge PITA to change spark plugs for me.
Damn duck pond sitting on top of my engine. Disgusted
Re: Fouling spark plugs Mon, 08 December 2003 03:38 Go to previous messageGo to next message
5's are hotter than 6's.. higher number = colder (for NGK anyways) Wink
ed_ma61
Lost in the K hole
Re: Fouling spark plugs Mon, 08 December 2003 03:44 Go to previous messageGo to next message
bugger
he's right you know Wink
Nark
Cabramatta, NSW
icon5.gif  Re: Fouling spark plugs Mon, 08 December 2003 04:08 Go to previous messageGo to next message
SoooOOoo.... My oxy sensor then? Or anything else that could be the cause?
VB gze
Gosford
Re: Fouling spark plugs Mon, 08 December 2003 05:14 Go to previous messageGo to next message
I thought the oxy sensors only worked when under low load, eg cruising?
Nark
Cabramatta, NSW
icon2.gif  Re: Fouling spark plugs Mon, 08 December 2003 22:08 Go to previous messageGo to next message
Hmm... I dunno...
I just figured that the oxysensor is the most likely cause of over fueling... Could be the AFM (unlikely) or not getting enough wattage to the ECU/injectors (quite likely although it's only just started happening).
E30-323ti
Re: Fouling spark plugs Mon, 08 December 2003 23:11 Go to previous messageGo to next message
Was it just 1 or 2 plugs?? or all 6 of them??
Do they all look the same (colour, deposits etc...), just thinking it could be leaky valve guide seals fouling the plugs.
Nark
Cabramatta, NSW
icon3.gif  Re: Fouling spark plugs Tue, 09 December 2003 00:15 Go to previous messageGo to next message
I'll take some photos and post them up tomorrow.
I'm just gonna install the new ones anyway. The car is an absolute POS to drive right now.
I just wish half the engine didn't have to come out every time I changed the spark plugs... Stupid duck pond sitting on top of my engine. Disgusted
Bugman
Re: Fouling spark plugs Tue, 09 December 2003 00:34 Go to previous messageGo to next message
get a real intercooler... does your ic ice up down in canberra?
Nark
Cabramatta, NSW
icon2.gif  Re: Fouling spark plugs Tue, 09 December 2003 22:19 Go to previous messageGo to next message
Dunno... When it's that cold, I'm not gonna hang around outside for long...... Smile
Changed the spark plugs but I left my digicam at home. I'll go grab it at lunch time and post the photos up.
punkdefender
Dandenong/VIC
Re: Fouling spark plugs Tue, 09 December 2003 23:44 Go to previous messageGo to next message
Just out of curiosity what spark plugs do you use?
Nark
Cabramatta, NSW
icon1.gif  Re: Fouling spark plugs Wed, 10 December 2003 00:11 Go to previous messageGo to next message
They're NGK BCPR6EY-11s. Although I accidentally bought BCPR5EY-11s which fouled really quickly.
punkdefender
Dandenong/VIC
Re: Fouling spark plugs Wed, 10 December 2003 03:11 Go to previous messageGo to next message
I got bcpr7es and I never seen a rough idle like that it was all over the place, then I use the ngk recommended platinum BCPR6EP-N-8 and its great
E30-323ti
Re: Fouling spark plugs Wed, 10 December 2003 03:56 Go to previous message
In my old Yamaha Motorbike it use to eat NGK plugs for breakfast, literally, start it up to go to work and it would run on 3 at least once a month. Changed to ND (nippon denso) plugs and it was alot better (once every 2 months!!).
Leaky valve guide seals was the source of the problem, didn't feel like pulling the engine out back then to fix them so I sold it with a new set of plugs!!
It is funny because I have seen a few older 4AGE's with leaky valve guides, both use yamaha heads!!!
Is there something wrong with the design or durability of them??
ed_ma61: you've had plently of yamaha heads apart!?!?!
ps. It is odd that it fouled the hotter plugs quicker, my old 1275GT mini use to run with 2 BP4ES & 2 BP6ES, bloodly cracked rings!!
[Updated on: Wed, 10 December 2003 03:59]
Previous Topic:1G-GTE Twin Turbo Auto to Manual Conversion
Next Topic:MX83 vs MX73
Current Time: Sat Oct 24 00:00:26 UTC 2026
Total time taken to generate the page: 0.0064990520477295 seconds
