Toymods » Tech & Conversions » 100kw 4AGE with TVIS manifold, possible?
Klint
100kw 4AGE with TVIS manifold, possible? Mon, 08 December 2003 05:50 Go to next message
I know that that you get good result with 100kw block and bigport head and TVIS intake.
My car is 89 MR2, so was wondering if i retain the TVIS manifold and use a complete 100kw 4AGE with smallport head. I get a custom-made adapter to fit TVIS manifold to small port head.
That way it will still look stock.
May use bigport ECU or aftermarket.
I don't think there will be any increased performance by doing that, but I'm hoping not to lose any.
Still thinking whether to keep the TVIS functional or cosmetic?
any opinion?
[Updated on: Mon, 08 December 2003 05:52]
Bill Sherwood
Brisbane / Gold Coast
Re: 100kw 4AGE with TVIS manifold, possible? Mon, 08 December 2003 06:27 Go to previous messageGo to next message
Yes, with a lot fo work you could do it, but why?
The Japanese big port TVIS engines are 97kW so not that far behind the 100kW small port, so why bother?
Anyway, a good small port head will beat a TVIS just about every time.
Klint
Re: 100kw 4AGE with TVIS manifold, possible? Mon, 08 December 2003 08:09 Go to previous messageGo to next message
Because 87-89 model MR2 came with the 7 rib block and internal like the 100Kw but with the TVIS bigport head and 9.4:1 CR
I was thinking of increasing the CR to 10.5:1 and put on smallport head.
Question is which manifold to use?
1. TVIS maninfold with TVIS active
2. TVIS manifold w/o TVIS active
3. any other option?
[Updated on: Mon, 08 December 2003 08:10]
._T_.
Re: 100kw 4AGE with TVIS manifold, possible? Mon, 08 December 2003 21:39 Go to previous messageGo to next message
the manifolds interchange. the stud spacing is the same.
personally i suggest you refit the bigport head, but the smallport head will work
T
Klint
Re: 100kw 4AGE with TVIS manifold, possible? Tue, 09 December 2003 09:06 Go to previous message
I wanted to use the small port head as it suppose to flow with higher velocity.
question is should i use back the bigport manifold with TVIS activated or not?
Previous Topic:turbo camry conversion help
Next Topic:Elec dizzy questions. M motors
Current Time: Fri Oct 30 05:21:59 UTC 2026
Total time taken to generate the page: 0.0048398971557617 seconds
