Classifieds » Miscellaneous » FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order
AZA510
Central Coast, NSW
FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Mon, 08 December 2003 06:01 Go to next message
Expression of interest / Order:
I can get some adapter plates made up to fit 4a (t-50) bellhousings to W5* (supra style) gearboxes.
kit will include:
- adapter plate
- spigot shaft bearing (one inside back of crank)
- adapter for spigot bearing
- 15 various bolts required.
are you willing to pay $320. Of course the more orders I get the cheaper it will be
contact
Aaron
0401 442 365
aza@icc.zzn.com
pannelvan_screema
Campbelltown, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Mon, 08 December 2003 06:13 Go to previous messageGo to next message
Hell yeah very very interested
Is this for w50+ or w55+
how much would postage be?? just curious ballpark figure will sufice
Richard
AZA510
Central Coast, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Mon, 08 December 2003 06:20 Go to previous messageGo to next message
from my knowledge any w5 box.. I have a w55 box I am putting one on and also a W57. 58 are also the same but I havent seen a 50. Im guessing because they are all w boxes they are all the same housings with different gears/in and out shafts
wilbo666
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Mon, 08 December 2003 06:42 Go to previous messageGo to next message
AZA510 wrote on Mon, 08 December 2003 17:20
nope.
W50's are steel case, where as W55, W57 and W58 are alloy case. They also have a different bellhousing pattern. I'd suggest only catering for the W55, W57, W58 market.
Offroad Industries
Silverwater
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Mon, 08 December 2003 20:36 Go to previous messageGo to next message
yea I'd be up for it
krayzie
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Tue, 09 December 2003 03:45 Go to previous messageGo to next message
Would you be able to post a pic of it. I would like to see the casting of the bellhousing.
Other then that im interested.
Andrew
moo4AGZETA22
Tasmania
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Tue, 09 December 2003 06:08 Go to previous messageGo to next message
Interested in 2 of them.
Justin
gt20v
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Wed, 10 December 2003 00:48 Go to previous messageGo to next message
I'll be interested if the toymods experts reckons it's well constructed and won't fall apart..
sprinterboy4agze
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Wed, 10 December 2003 02:30 Go to previous messageGo to next message
i'll take one
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Wed, 10 December 2003 14:16 Go to previous messageGo to next message
If you read the original post carefully, it's not a cast bell housing but a machined adaptor that will allow you to bolt the original T50 bellhousing to a W55, W57 or W58.
Slabs of machined alloy don't fall apart too easily! Smile
gt20v
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Thu, 11 December 2003 00:26 Go to previous messageGo to next message
oic, thought it's the usual custom welded bellhousing, so have you seen it working?
AZA510
Central Coast, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Thu, 11 December 2003 01:03 Go to previous messageGo to next message
As there is some interest I will be making some up. Please if you DEFINITELY want one please email me or call me as I am putting a list together of orders.
At the moment I am making one only so I can install it in a test car. When this car is up and running I will be making sure they are safe and the clutch can still engage and disengage properly.
This is just an adapter plate, NOT a full casting.
The Kit includes:
-adapter plate
-spigot bearing spacer
-spigot bearing
-various bolts
I have had some growing concern with clutch plates. As you maybe aware the input shaft on the W gearboxes are larger then the t-50 gearboxes. therefore a new clutch plate will be needed with the bigger centre spline. I maybe able to add a clutch plate to the price of the kit although my problem with this is the fact that there are two or three different sized clutch plates. the GZE and the GE flywheels are different. therefore I WILL be able to send one with the adapter but you will NEED to tell me:
a. what the flywheel is out of.
b. the inside diameter of the clamping area
c. the outside diameter of the clamping area
this way I can order the right plate / clutch kit for you.
Please as I said if you are interested and DO want one call me or email me and I can add you to the list. please email me you phone number also.
regards
Aaron
0401 442 365
aza@icc.zzn.com
4AGE
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Fri, 12 December 2003 05:17 Go to previous messageGo to next message
Hmmz. How would this happen??? Are they a die cast?
Well put me down anywayz.
AZA510
Central Coast, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Thu, 18 December 2003 09:41 Go to previous messageGo to next message
when the proto-type is finished I will be taking photos and deposits. until then hold tight, it will be 2 week of new year.
[Updated on: Thu, 18 December 2003 09:48]
pannelvan_screema
Campbelltown, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Sun, 21 December 2003 00:57 Go to previous messageGo to next message
Hey dude if it works, is strong and reliable, and it comes as a complete kit start to finish i will have one definatley!!
so im guessing u cant use a normal 4A clutch.?.
Anyway i have a standard 100Kw
Richard
AZA510
Central Coast, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Mon, 22 December 2003 23:16 Go to previous messageGo to next message
hey they will be strong.. the alloy plate is made of 5083 grade alloy.. and is 20mm thick..
yes you use a different clutch center. I know that if you clutch still has a bit of meat on it you can go to custom clutch places and get new splines put in... but I mayeb selling plates with the kits anyway.
AZA510
Central Coast, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Mon, 12 January 2004 01:42 Go to previous messageGo to next message
sorry all I have a few problems getting the plates cut.. it shouldnt be too much longer.. also the car I was going to use to test with is not ready.
pannelvan_screema
Campbelltown, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Tue, 20 January 2004 00:56 Go to previous messageGo to next message
Hey dude how are the bellhousings comin along??
Not a hurry up just wonderin.
Richard
pannelvan_screema
Campbelltown, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Thu, 22 January 2004 14:11 Go to previous messageGo to next message
^BUMP^
AZA510
Central Coast, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Fri, 23 January 2004 09:24 Go to previous messageGo to next message
sorry everyone I should have up dated earlier..
next week is the week where I will be testing this product and see if there is anything that is overlooked.
krayzie
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Sat, 24 January 2004 23:34 Go to previous messageGo to next message
BUMP
Hirogen
Melbourne, Australia
      WTF is a jabber?
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Mon, 26 January 2004 04:27 Go to previous messageGo to next message
Im interested too, keep us apprised of your testing.
krayzie
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Wed, 04 February 2004 01:29 Go to previous messageGo to next message
Any update on this????
Bazooka
Gold Coast
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Wed, 04 February 2004 10:24 Go to previous messageGo to next message
Aaron messaged me today and said that the cutters have cut the plate wrong and so has to get them redone. I dont know how much longer that will take.
krayzie
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Fri, 06 February 2004 02:33 Go to previous messageGo to next message
I hope its not too far away from getting done. My gearbox is hammered so far I dont know how much longer it will last.
c2888
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Fri, 06 February 2004 06:15 Go to previous messageGo to next message
Interested
I broke 2nd gear on monday Very Happy
dodgydan
pannelvan_screema
Campbelltown, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Sun, 08 February 2004 01:53 Go to previous messageGo to next message
Hey dude join the club my seccond gear went CYA aswell. Shits me hard drivin 1st-3rd-4th-5th Very Happy
Keep us posted dude.
Richard
krayzie
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Wed, 11 February 2004 08:06 Go to previous messageGo to next message
Sorry to be annoying but any word on these adapters yet?
Bazooka
Gold Coast
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Thu, 12 February 2004 04:15 Go to previous messageGo to next message
Hopefully we should be seeing something next week.
Sparkle86
Ballarat, Vic
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Tue, 23 March 2004 07:38 Go to previous messageGo to next message
Just wondering if there is any news on these adaptors. I recently suffered the crunch crunch bang bang that seems to happen all to frequently to the old T50, and am now looking for a stronger replacement.
Aaron (colligan@bigpond.com)
pannelvan_screema
Campbelltown, NSW
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Tue, 23 March 2004 10:13 Go to previous messageGo to next message
Yes i also am very interested in whats happening with them. i need one very soon!!!
Richard
Twinky
N.S.W
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Sun, 28 March 2004 05:27 Go to previous messageGo to next message
Im very interested Very Happy
monkeymajik
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Sun, 28 March 2004 05:34 Go to previous messageGo to next message
I'm interested if it's a start to finish kit.
Sam_Q
S.E suberbs, Vic
Re: FS: t-50 bellhousing to W5* gearbox adapter kits, expression of interest / order Mon, 29 March 2004 08:46 Go to previous message
I am interested also, so would an off the shelf clutch be available to suit this setup? and what what would it of initially of come out of?
Previous Topic:4AGE C52 Gearbox *sold*
Next Topic:Brand new JDM RSM LE with G-sensor
Current Time: Thu Nov 19 19:13:29 UTC 2026
Total time taken to generate the page: 0.0075578689575195 seconds
