Classifieds » Miscellaneous » 15x7" Simmons B45's
15x7" Simmons B45's Mon, 08 December 2003 08:02 Go to next message
Hey guys,
Yes, these things are for sale again, now we've had a good look at them and polished them up. After measuring them again from the right spots, they are indeed 7" wide...as we suspected! Smile They are roughly 8mm offset.
As mentioned, they are now polished and as you can see in the pics they have been cleaned up and sprayed white.
There is still a couple of little dents in them, will try to get some better pics later since they have been polished.
For now, here is a couple of pictures:
http://oz-enet.com.au/~peewee/simmon5.jpg
http://oz-enet.com.au/~peewee/simmon3.jpg
We're looking for $1000ono, or will remove the tyres for $20 (this will save heaps on freight). Got any questions, just ask.
Nathan
[Updated on: Mon, 22 December 2003 14:56]
Re: 15x8" Simmons B45's Mon, 08 December 2003 09:29 Go to previous messageGo to next message
This is probably a better picture:
http://oz-enet.com.au/~peewee/simmons_step5.jpg
Stefan
Hobart, Tas
Re: 15x8" Simmons B45's Mon, 08 December 2003 23:35 Go to previous messageGo to next message
Hi Frank - how's the XX going? I'd love the rims but don't have any $$$
Are you sure that they're 8" wide - a 7" rim is 8" lip to lip, hence the confusion with a lot of people saying MA6x supra rims are 8"s wide (it says JJ8 for offset, you tell them that, they disagree then they measure them and say "see?" Smile )
Re: 15x8" Simmons B45's Tue, 09 December 2003 01:40 Go to previous messageGo to next message
It's going slowly. I didn't measure them, I'll get someone to measure them again.
Re: 15x8" Simmons B45's Tue, 09 December 2003 04:42 Go to previous messageGo to next message
http://oz-enet.com.au/~peewee/simmons.GIF
13BTA22
Re: 15x8" Simmons B45's Thu, 11 December 2003 03:52 Go to previous messageGo to next message
I am interested in the mags but are they 114.3 cause i think they would add a nice touch to the old TA22. Cool
Re: 15x8" Simmons B45's Thu, 11 December 2003 03:56 Go to previous messageGo to next message
Ummm, they fit most RWD 4 stud Toyotas (AE86, MX73, MA61) are the only ones I know for sure, so if you are compatible with any of them, it will fit
13BTA22
Re: 15x8" Simmons B45's Thu, 11 December 2003 04:07 Go to previous messageGo to next message
Thanks mate i shall do some research.I'll be back
bbaacchhyy
Re: 15x8" Simmons B45's Thu, 11 December 2003 04:42 Go to previous messageGo to next message
If they fit a Supra, they'll fit the TA22 for sure. From the measurements, the offset is about +8mm
Perfect fro a MA61 !!
Michael B
Celia-Sue
Re: 15x8" Simmons B45's Thu, 11 December 2003 05:05 Go to previous messageGo to next message
Hiya JCMF,
How's it going? Those Simmons look shweet! Pit they're only 15" - makes big brakes a bit harder (which is one of the main reason people upgrade on MA61s). But 8" does allow for some nice fat rubber!
I finally sold my 8"ers and bought a cheap set of stock rims. Spent weeks polishing & painting.
Good luck with the sale and keep us posted on the mighty GA61 twin turbo.
Justin
Re: 15x8" Simmons B45's Thu, 11 December 2003 06:28 Go to previous messageGo to next message
Yeah, dumbass here probably should have mentioned they were 4x114.3 Smile They even fit under the non-flared arches (just).
The XX is dorment atm, half primed as I ran out of money for primer...stupid f'ing Christmas Sad
13BTA22
Re: 15x8" Simmons B45's Thu, 11 December 2003 07:16 Go to previous messageGo to next message
I am interested but can you chnage the offset of these puppies.I am sure i will have to cause i have a hilux in the rear. It may be a stupid question but I want to make sure.
Re: 15x8" Simmons B45's Thu, 11 December 2003 07:34 Go to previous messageGo to next message
They're Simmons dude, the only thing your bound to, is the diameter, ie 15"
To go wider,thinner,diff offset, diff pattern, all you have to do is ring up Simmons, and get 4 new parts (whether they be inner rims, outer rims, or centres)
Dunno on cost, but its possible
bbaacchhyy
Re: 15x8" Simmons B45's Thu, 11 December 2003 21:16 Go to previous messageGo to next message
I believe that with the B45's, you can still go to 16" with the same centres.
Last time I rang Simmons, I think the 16" outers from 1/2" to 2 1/2" were the same price, and they were $200 each polished.
I may be doing something similar, as my 16 x 8"s are great on the front, but with the offset, the rears should be able to go to 16 x 9".
Michael B
13BTA22
Re: 15x8" Simmons B45's Thu, 11 December 2003 22:23 Go to previous messageGo to next message
So on B45's you can use the 15 inch centre and put a 16inch rim on it. How do they do that?
bbaacchhyy
Re: 15x8" Simmons B45's Thu, 11 December 2003 22:30 Go to previous messageGo to next message
Just use different inner and outer rim halves.
To be sure, check with the Simmons authorised dealer
Michael B
Re: 15x8" Simmons B45's Fri, 12 December 2003 00:26 Go to previous messageGo to next message
Yeah, he's right
When Simmons first brought out the B45 in a 16" format, they just used the same centre, and a bigger inner/outer
Instead of coming straight out towards the outside, it went up 1/2 an inch, then outwards, thus making it 1" larger
Re: 15x8" Simmons B45's Mon, 15 December 2003 02:19 Go to previous messageGo to next message
Price is negotiable ppls
^bump^
Re: 15x8" Simmons B45's Mon, 22 December 2003 14:52 Go to previous messageGo to next message
Bumpety bump bump. Still for sale...would LOVE to get rid of them to make room for 1UZFE. Smile
Re: 15x7" Simmons B45's Mon, 05 January 2004 02:14 Go to previous messageGo to next message
Burmpy
WA_TRD_83
Perth, WA
Re: 15x7" Simmons B45's Tue, 06 January 2004 14:44 Go to previous messageGo to next message
Sorry dood - as you know I'm already rocking the 16" x 8 Simmons B45's on my Mk2 Supra Very Happy
The rims came up good though - you should be able to sell them. I'll let my people know in case anyone is interested.
Damo
Re: 15x7" Simmons B45's Tue, 06 January 2004 14:53 Go to previous message
Thanks Damo, but at the mo, they have already been sold
Previous Topic:got one
Next Topic:set of mags for sale "SOLD"
Current Time: Wed Oct 28 18:06:15 UTC 2026
Total time taken to generate the page: 0.0062770843505859 seconds
