Toymods » Tech & Conversions » Cold Start Injector? Hard Cold Starting
Asher
Northgate, QLD
Cold Start Injector? Hard Cold Starting Tue, 09 December 2003 01:07 Go to next message
Me again,
Ok my 22r-e corona is bloody hard to start in the morning, it takes quite a few cranks and conk outs before the pussy actully gets started, but once it gets going shes fine as.
I filled my tank up last night and put some Spit Fire injector cleaner in but I probably wont get through this fuel tank for atleast another week, so probably wont make any difference.
How hard is it to take the injectors out and clean them my self, and what chemicals and tools (toothbrush?) should I use?
Or should I get them sent away to get professionally cleaned by some ultrasonic machiney thing?
Asher
[Updated on: Tue, 03 February 2004 04:06]
Re: Injectors? Hard Starting Tue, 09 December 2003 01:18 Go to previous messageGo to next message
You can't clean them without specialised equipment, and if you attempt to do so with a toothbrush you'll totally root them! Leave it to the pros; it's not that expensive to get done.
SIMDOG
Bayside Melbourne.
Re: Injectors? Hard Starting Tue, 09 December 2003 01:19 Go to previous messageGo to next message
I dunno if it is a common problem with Toyotas but my Cressida is a bitch to start unless it has just been turned off or has been left for more than a day. Any other times it takes heaps of cranking to fire up.
I replaced the injectors... replaced the O2 sensor... platinum plugs are a month old... leads are good... checked it out with a diagnosis computer... no improvement or answers. Mad
Sorry to sound a bit negative but I have wasted about a grand trying to find the problem and have given up.
[Updated on: Tue, 09 December 2003 01:20]
Asher
Northgate, QLD
Re: Injectors? Hard Starting Thu, 11 December 2003 23:35 Go to previous messageGo to next message
Replacing all the leads which fixed some of the starting troubles but still striving to start, guessing injectors atm. Lube Mobile coming out saturday to come clean them for me.
CLG
Perth, Western Australia
Re: Injectors? Hard Starting Fri, 12 December 2003 01:57 Go to previous messageGo to next message
My injected car used to take a couple of seconds to start, was never hapyy with it. Pulled the injectors to be cleaned, and found that they all leaked fuel, resulting in low pressure behind them. The engine had to crank (to activate the fuel pump), which then built the pressure up behind them, which once done allowed the car to start effectively. Once they were ultrasonically cleaned, they never leaked, and my car now starts on first crank everytime.
RobST162
Re: Injectors? Hard Starting Fri, 12 December 2003 01:58 Go to previous messageGo to next message
cool can you get that "ultrasonic" cleaning done at most workshops?
I will just take my injectors out and get 'em done
rvrolla
Central Coast
Re: Injectors? Hard Starting Fri, 12 December 2003 02:08 Go to previous messageGo to next message
Not sure if it helps, but it was supspected that the cold start injector on my old 7mgte was r00ted. We didn't end up cleanin or replacinjg it though...
Asher
Northgate, QLD
Re: Injectors? Hard Starting Fri, 12 December 2003 05:45 Go to previous messageGo to next message
hummm,
http://www.lubemobile.com.au/services.php
Says they do some type of de-carbonising purge of the whole system which "Guaranteed to clean the injectors like new."
So I don't think they ultrasonicly clean them...
You guys think I should get him to pull one out and show me it's cleaned before he tottles off in his mobile?
CLG
Re: Injectors? Hard Starting Fri, 12 December 2003 05:46 Go to previous messageGo to next message
RobST162 wrote on Fri, 12 December 2003 09:58
Ask questions before you hand them over, some shops just pulse them with a cleaning solution, while others replace filters, seals, o rings, and still have them sonically cleaned before doing so.
Another easy tuning tip I've used regularly is to remove the cold start injector, spray it with carby cleaner to remove residue, and replace, this sometimes helps with hard starting.
SIMDOG
Bayside Melbourne.
Re: Injectors? Hard Starting Fri, 12 December 2003 10:48 Go to previous messageGo to next message
Before I got the injectors replaced I thought that a "Carbon Clean" might help the bad starting on my 7M-GE because a few mechanics recommended it... I think what they do is run some kind of carbon dissolving fluid through the whole sytem. It sounded like they actually run the car on the stuff like it runs on petrol. They connect it up to the fuel pickup and run it for about 45min.
Needless to say, it didn't help me... but the mechanics assured me it was worth treating your engine to every once in a while.
sideshow
Re: Injectors? Hard Starting Fri, 12 December 2003 12:18 Go to previous messageGo to next message
also make sure the cold start injector or system is workin
this injects extra fuel when crankin
Asher
Northgate, QLD
icon9.gif  Re: Injectors? Hard Starting Tue, 03 February 2004 03:30 Go to previous messageGo to next message
Ok, this is getting bad. It was only slightly cold this morning, this could get ugly when winter rocks round.
Took about 6-8 gos of the engine going to start then dieing before it reaches 700rpm. Then finally it fired up and idled fine.
Once the car starts, shes all good but the whole cold starting just doesn't work.
Is there a way I can test to see if the cold start injector is actually firing?
Anyone got any suggestions on how to do some diagnostics?
CLG
Re: Injectors? Hard Starting Tue, 03 February 2004 05:13 Go to previous messageGo to next message
Does your car also run an idle bypass circuit? check to see if this is working too. Failing that, take the bloody thing to a reputable mechanic - the fact the car is still having this problem only proves the steps taken so far have not fixed it, and it's time to look further than your (and our) field of knowledge.
STR8 2.8
Re: Injectors? Hard Starting Tue, 03 February 2004 07:46 Go to previous messageGo to next message
take it out stick it in a bottle, plug the hole with rags and turn the engine over, see if it dumps petrol in the bottle.
sideshow
Re: Cold Start Injector? Hard Cold Starting Tue, 03 February 2004 08:19 Go to previous messageGo to next message
check voltage to fuel pump
i have seen this heaps of times
make sure u have over 12 volts to the fuel pump when crankin
Re: Cold Start Injector? Hard Cold Starting Tue, 03 February 2004 22:47 Go to previous messageGo to next message
as far as im aware, cold start injectors really dont make much of a difference unless the engine is at a below zero degree temperature. I dont have mine connected on my 4age, and i have NO PROBLEMS starting it....
Re: Cold Start Injector? Hard Cold Starting Tue, 03 February 2004 22:59 Go to previous message
Likewise with my 18R-GEU. The CSI isn't hooked up and it starts easily even in the coldest weather (well, as cold as it gets up here).
Previous Topic:Ig-gte turbo question's
Next Topic:AE86???
Current Time: Sun Oct 18 00:47:59 UTC 2026
Total time taken to generate the page: 0.006134033203125 seconds
