Toymods » Tech & Conversions » Aluminium Crank Pulley - Smart People Look Here!
gabe
Aluminium Crank Pulley - Smart People Look Here! Tue, 09 December 2003 03:36 Go to next message
I was going to machine up a nice aluminium crank pully for my 3sgte but have been told by a mate it upsets the harmonics of the engine. Thats why they have rubber in them. To be honest I didnt follow his arguement that well.
Anyway, I would have thought this would have a similar effect to lightening your flywheel........Any thoughts on this would be much appreciated!!
[Updated on: Tue, 09 December 2003 03:40]
Re: Aluminium Crank Pulley - Smart People Look Here! Tue, 09 December 2003 03:55 Go to previous messageGo to next message
Yes, crank pulleys are important for harmonic balance and shouldn't be messed with. The reduction in rotating mass is likely to have a negligible effect anyway; a crank pulley is much lighter than a flywheel, and it has a much smaller diameter as well, so it doesn't have that much inertia.
Re: Aluminium Crank Pulley - Smart People Look Here! Tue, 09 December 2003 03:58 Go to previous messageGo to next message
Well known problem with the 2JZGTE, particularly when running an auto. Some of the guys have been running lightweight underdrive crank pulleys. Apparently, due to crank length and other reasons, harmonic vibrations are setup along the length of the crank. These are particularly magnified at cylinder number 1. This results in 'crank walk' and also loosening of the flexplate bolts. Apparently doesn't happen with the manual variants - the dual mass flywheel and its weight are supposedly protective. Reg Reimer has a nice page on it somewhere - lost all my bookmarks with a reformat.
Not sure how it translates to your 3SGTE.
Ben Wilson
Re: Aluminium Crank Pulley - Smart People Look Here! Tue, 09 December 2003 04:30 Go to previous messageGo to next message
Replacing harmonic balancers with solid pulleys has been known to cause problems with 6 and 8 cylinder engines, I've yet the hear of anyone having problems with a Toyota 4 (and there are a bunch of people running NEVO pulleys on 4AGZE's).
._T_.
Re: Aluminium Crank Pulley - Smart People Look Here! Tue, 09 December 2003 06:08 Go to previous messageGo to next message
ben,
on race 4age's there have been a number of crank failures due to modified or solid harmonic balancers. certainly less common than 6 cylinder failures, but they will fail eventually.
T
gabe
Re: Aluminium Crank Pulley - Smart People Look Here! Tue, 09 December 2003 06:22 Go to previous messageGo to next message
So the general view is dont mess around with it unless its absolutely necessary.
The reason for the aluminium pulley was purely wank factor, and was in no way intended for a performance gain.
Righto fellas cheers.
5KinKP60
Finland
Re: Aluminium Crank Pulley - Smart People Look Here! Tue, 09 December 2003 06:53 Go to previous message
The Danger of Power Pulleys &
Understanding the Harmonic Damper
By Steve Dinan
http://dinancars.com/html/danger_of_power_pulleys. htm
http://dinancars.com/default.htm
Previous Topic:Elec dizzy questions. M motors
Next Topic:Gen 2 Camry with WRX rims?
Current Time: Thu Oct 29 18:17:33 UTC 2026
Total time taken to generate the page: 0.042786836624146 seconds
