Toymods » Tech & Conversions » 100kW Pistons in a 7 Rib TVIS Engine??
de_rift
Wollongong
100kW Pistons in a 7 Rib TVIS Engine?? Tue, 09 December 2003 05:13 Go to next message
So does it fit?
How much are a set of 100kW pistons worth?
Would I need to do any engine work or buy any parts to fit them such as rings etc?
._T_.
Re: 100kW Pistons in a 7 Rib TVIS Engine?? Tue, 09 December 2003 06:07 Go to previous messageGo to next message
if it's a aw11 7 rib then they will fit.
how much? anything from about $200 a set upwards
T
Grega
melbourne.victoria.austra...
Re: 100kW Pistons in a 7 Rib TVIS Engine?? Tue, 09 December 2003 19:57 Go to previous message
what T said - the aw11 7 rib is almost the same as the ae92/3 7 rib minus the oil squirters and running a bigport head. it runs the 42mm big ends.
plus, if you're going to the bother then yes a set of rings and a light hone (if your bore is in good nick) would be a good idea amongst other things...
Previous Topic:headlight conversion TA22
Next Topic:plumbing
Current Time: Sun Nov 1 18:03:06 UTC 2026
Total time taken to generate the page: 0.012615919113159 seconds
