Toymods » Tech & Conversions » Noisy 7mge head
amichie
Home
Noisy 7mge head Wed, 10 December 2003 05:39 Go to next message
Hello
My 7mge motor makes load tapping sounds above 3000rpm when hot. Much less noise when cold and at low rpm. it gets much louder as you rev it up.
Any thoughts?
Danners
Central Coast, NSW
Re: Noisy 7mge head Wed, 10 December 2003 05:42 Go to previous messageGo to next message
Possibly the valve shimms need re-adjusting/re-shimming?? anyone??
Very Happy
Dan
FKN16V
NSW, East Coast
Re: Noisy 7mge head Wed, 10 December 2003 07:26 Go to previous messageGo to next message
Could be lack of oil too.
When the oil is changed does it change color after a short run, say 200-300 kms could be an oil block somewhere and the oil is cooking.
celicaboy_2000
Lismore, NSW
Re: Noisy 7mge head Wed, 10 December 2003 08:45 Go to previous messageGo to next message
I'd say you would need to check your valve clearence's, also how do you know for sure it coming from the head? Could be a collapsed piston... Check your valve 1st tho if there loose replace the shims to suit the clearence's. Let us know how you go...
ed_ma61
Lost in the K hole
Re: Noisy 7mge head Wed, 10 December 2003 08:55 Go to previous messageGo to next message
my money is on a dying big-end rod bearing
ed_ma61
Lost in the K hole
Re: Noisy 7mge head Wed, 10 December 2003 08:58 Go to previous messageGo to next message
mine was making the same noise back in june, and as time has shown, guess what it turned out to be::
http://forums.toymods.org.au/index.php?t=msg&t h=14843&rid=92&S=510737661e176ac3f1e347168 033f718&pl_view=&start=0#msg_120750
amichie
Home
Re: Noisy 7mge head Wed, 10 December 2003 09:54 Go to previous messageGo to next message
The car doesn't use any oil and it stays clean for months before discolouring after a change.
amichie
Home
Re: Noisy 7mge head Wed, 10 December 2003 10:03 Go to previous message
So what was it in the end?
Previous Topic:5M-GE to 7M-GE
Next Topic:Suspected blown head gasket
Current Time: Sun Oct 18 11:54:37 UTC 2026
Total time taken to generate the page: 0.0062341690063477 seconds
