Toymods » General Car Talk » Unichip, r they a good idea?
thug_immortal
Camden, NSW
Unichip, r they a good idea? Wed, 10 December 2003 07:57 Go to next message
Just wondering if this would be a quick fix to a small lack of power in the 7mgte? They say that for 900 bucks u can get your car running 202kws. Seems ok to me, but just wondering on your thoughts, should i just fork out the extrra money n buy a microtech or would this be a good solution for the near future untill i really wanna get some good power gains out of her?
Re: Unichip, r they a good idea? Wed, 10 December 2003 08:20 Go to previous messageGo to next message
On a stock MA70? Waste of time. You can get well into the 13's with the standard ECU and 12's aren't hard with the Lexus AFM mod. Your $900 could be better spent elsewhere.
thug_immortal
Camden, NSW
Re: Unichip, r they a good idea? Wed, 10 December 2003 08:23 Go to previous messageGo to next message
Thanks Norbie, knew i could count on you Very Happy
Im sorta at the stage where i dunno what to do to my car :S, its too slow for me as is, Ill be fitting a 3" exhaust once the car is back on the road but after that not too sure what the next step will be :S
Re: Unichip, r they a good idea? Wed, 10 December 2003 08:41 Go to previous messageGo to next message
A decent 3" exhaust (including dump pipe, not just a cat-back) and a bleed valve will get your car into the high 13's, which is plenty quick for a street car. The next thing I'd do is get rid of the piss-poor factory intercooler and replace it with something decent. Beyond that, a high-flow CT26 and the aforementioned Lexus AFM upgrade sounds like a good idea, and by then you should be doing 12's. As the current owner of a 12 second car I can tell you you'll be faster than practically everything on the street!
Of course you should re-torque the head on that 7M before you do any of this, if you haven't done so already. I'd also upgrade the headgasket before high-flowing the turbo, just to be safe.
thug_immortal
Camden, NSW
Re: Unichip, r they a good idea? Wed, 10 December 2003 09:59 Go to previous messageGo to next message
Yeah, as we speak (well during the day neway Razz) i have a metal gasket going in with arp bolts, the head has a tiny crack in it so gotta get that fixed this week sometime if its fixable Confused and then when its back on the road, 3" from the turbo back (should i go bigger?) and then bleed valve. As you said, a new cooler will be on the way, but thats all i had planned. The lexus afm, if i put a new ecu in, wont it change to map? isnt map easier to tune etc? Or isnt it worth the hassle as stock ecu is good enough?
Re: Unichip, r they a good idea? Wed, 10 December 2003 13:04 Go to previous messageGo to next message
It depends how far you want to go, but if you're keeping the CT26 there's not much to be gained from an aftermarket ECU IMO.
As for the exhaust, again with a CT26 there's no point going further than 3". Of course you can put a 4" system on if you like, but it will only be noisier.
thug_immortal
Camden, NSW
Re: Unichip, r they a good idea? Thu, 11 December 2003 03:48 Go to previous messageGo to next message
what is a good feul cut defender? i wanna run around 12-15psi but i cant because of feul cut, how much is it going to set me back?
Re: Unichip, r they a good idea? Thu, 11 December 2003 05:21 Go to previous messageGo to next message
The fuel cut is there for a reason; IMO you should not install a FCD without supporting mods. If you do the Lexus AFM mod your fuel cut will be moved up to 20psi or so, and because you're increasing the capacity of the fuel system it's safe to run that much boost.
2Lsupra
Re: Unichip, r they a good idea? Sun, 14 December 2003 16:52 Go to previous messageGo to next message
wot are these supporting mods your talkin about??
sideshow
Re: Unichip, r they a good idea? Sun, 14 December 2003 21:54 Go to previous messageGo to next message
yr are at the stage nbow where u have to spend alot of money to get it goin faster
u have done all the cosmetic stuff round the outside of the engine
now if u want good power u will prob have to
turbo upgrade
ecu upgrade
maybe forged pistons
descent intercooler
thats over 5000 grand worth of stuff there
i would either not spend too much and save for bigger turbs and ecu
if u build yr engine up slowly it will cost u more in the long run
think about how u want yr engine to be in 3 or 4 yrs
save the money now and do it soon rather than doin abit now abit later and so on
the problem with little increases in power is u get used to it very quickly and after afew days u still want more power
4DaDrift
Re: Unichip, r they a good idea? Mon, 15 December 2003 01:48 Go to previous messageGo to next message
meh if ur going 2 spend $5k go 4 a 2jzgte conversion ...
Re: Unichip, r they a good idea? Mon, 15 December 2003 03:15 Go to previous messageGo to next message
I'd love to see a 2JZ conversion done for $5k! Laughing
pimp1j
Re: Unichip, r they a good idea? Mon, 15 December 2003 03:35 Go to previous messageGo to next message
mos Smile
thug_immortal
Camden, NSW
Re: Unichip, r they a good idea? Mon, 15 December 2003 06:46 Go to previous message
ok...
I am now thinking of the afm + injector upgrade. Ive searched the forums n see that the rx7 injectors are the ones to use?
How much would the lexus afm set me back? Are they readily available from wreckers? or should i just get it through toyota?
Also, will i need a feul pressure regulator and bigger feul pump or will the standard ones do the job? If i need a bigger pump, is there a cheaper option than a brand new bosch? like a 2nd hand 5ltr pump of a holden or something?
Sorry for what may seem stupid questions to some but i really have no idea with this sort of thing.
Previous Topic:F#@king C*#ts smashed my windscreen! where to go for an new one?
Next Topic:Zoom's new Project Car - MX83 Grande with 7M-GTE !!!
Current Time: Tue Oct 20 15:56:16 UTC 2026
Total time taken to generate the page: 0.0058200359344482 seconds
