Toymods » Tech & Conversions » 12a turbo on a 18rgeu. Also injector questions.
people100
Rocklea qld
12a turbo on a 18rgeu. Also injector questions. Wed, 10 December 2003 10:08 Go to next message
My father inlaw works in a mazda wrecker and can get a 12a turbo for basically nothing so my question is will it run well on a 18rgeu. Also i was told that all injectors will fit all rails. is this true. If so how would something like v6 commodore injectors go in a turbo'd 18rgeu. what cc are they and what would be the best cc injector to run with the standard ecu. Ive done a search but must be doing something wrong because i cant find any of the info im after but im sure its been said before. Any help would be great. Also is there a legal limit for how low you can sit an engine in a engine bay as ive lowered mine and theres about 5mm between the sump and the crossmember. will this help with handling at all.
Re: 12a turbo on a 18rgeu. Also injector questions. Wed, 10 December 2003 11:24 Go to previous messageGo to next message
woops . i guess you meant a turbo off a 12A rotary? sorry, don't know...
Injector shapes vary across different manufacturers.
For more info about flow, see here:
<http://www.autospeed.com/cms/article.html?&A=0 102&P=1>
and here:
<http://www.bsmotor.com/cgi-bin/bsmotor/dyser/dyser .bsp?trykk=2.5&af=12.0&ant=6&pros=65>
for calculating fuel requirements for engines, this might help:
<http://members.shaw.ca/megasquirt/manual/minj.htm# size>
although it's US based ... but it does inform you more about injectors.
[edited to remove studid error about turbo]
charles.
[Updated on: Wed, 10 December 2003 11:42]
Re: 12a turbo on a 18rgeu. Also injector questions. Wed, 10 December 2003 12:49 Go to previous messageGo to next message
A 12A turbo will probably work OK but it will be laggy. Turbos designed for rotaries generally have large exhaust housings, which means they flow well at high rpm but they're inefficient at low rpm.
Whoever told you all injectors fit in all rails is an idiot. As Charles mentioned there are many variations which are completely incompatible. You will find that most Toyota/Nissan NipponDenso injectors will fit in your fuel rail though.
TurboRG
Nor Calif USA
Re: 12a turbo on a 18rgeu. Also injector questions. Wed, 10 December 2003 18:47 Go to previous messageGo to next message
How about Mits injectors? Will they fit Toyota rails?
people100
Rocklea qld
Re: 12a turbo on a 18rgeu. Also injector questions. Thu, 11 December 2003 11:55 Go to previous messageGo to next message
Whats the best injectors around 350cc that i could get from any wrecker for nicks. Or does any body have any for sale.....what about out of a v6 commy or something like that.....
10sec_rx7
Syndey
Re: 12a turbo on a 18rgeu. Also injector questions. Thu, 11 December 2003 23:14 Go to previous message
the 12a turbo is very small compared to the 13b turbo, it will probably work quite well, the 13b turbos work well on 2L and above,
get some 7mgte injectors they are 440cc and around $100 each.
dale
Previous Topic:Landcruiser engine
Next Topic:Which Garrett turbo is this?
Current Time: Thu Nov 19 10:42:21 UTC 2026
Total time taken to generate the page: 0.022298812866211 seconds
