Toymods » Tech & Conversions » oil pressure gauge
tim123c
oil pressure gauge Wed, 10 December 2003 21:41 Go to next message
If i want to put an Autometer Electric Oil pressure gauge instead of the factory GZE gauge, should i simply be able to disconnect the old gauge and connect the new one to the existing wires, or do you think i'll need to change the oil pressure sender to suit the new gauge??
Re: oil pressure gauge Wed, 10 December 2003 22:20 Go to previous messageGo to next message
Yes, you'll need to change the sender as well.
Cyber-punk
Brisbane, QLD
Re: oil pressure gauge Wed, 10 December 2003 22:23 Go to previous messageGo to next message
ever so slighty off topic
if i were to put a mechanical oil pressure gauge on a 5m-e...what line would i tap into?
or should i stop being cheap and get an electric one(plus sender unit thingo i'd imagine?)?
Re: oil pressure gauge Wed, 10 December 2003 22:32 Go to previous messageGo to next message
Doesn't make any difference in that regard if you get a mechanical or electric gauge - they both have to tap into an oil gallery somewhere!
The easiest way is to get a T-piece and tap into the same place as the factory idiot light sender.
ra23celica
Re: oil pressure gauge Wed, 10 December 2003 23:46 Go to previous messageGo to next message
Adding to what Norbie said, just get a 1/8 NPT barb fitting to screw into your existing idiot light sender point, attach a hose to this fitting, fit a t-piece with a barb for the hose and two 1/8 NPT fittings and screw your idiot light in one side and the line to the gauge in the other.
Mitch.
ed_ma61
Lost in the K hole
Re: oil pressure gauge Thu, 11 December 2003 00:44 Go to previous messageGo to next message
there should be a spare tap into the oil gallery feeder rail near the oil filter
Grega
melbourne.victoria.austra...
Re: oil pressure gauge Thu, 11 December 2003 00:54 Go to previous messageGo to next message
idiot light i'll pay that Very Happy
um, on the GZE if you get a autometer like i have you will end up with clearance problems with the big brass can that goes in the oil pressure switches place - you will definately need a tee piece, and as mitch put it 1/8 NPT (tapered thread) is what the thing is - your autometer gauge will come with this thread anyways.
a speedflow 911-2 and 917-2 would be the go here. sources recommend not using brass as they are prone to snapping.
tim123c
Re: oil pressure gauge Thu, 11 December 2003 11:24 Go to previous message
Thanks everyone,
Yeh its the autometer with the brass cylinder looking sender.
Looks like the T piece is the go...
Previous Topic:O-ringed Blocked Assembly (7MGTE)
Next Topic:4A RWD Auto
Current Time: Mon Oct 26 03:17:38 UTC 2026
Total time taken to generate the page: 0.0042948722839355 seconds
