Toymods » Tech & Conversions » Can Head Bolts Be Reused?
gabe
Can Head Bolts Be Reused? Thu, 11 December 2003 06:54 Go to next message
Pulled the head off my 3sgte and I can remember reading somewhere that the headbolts actually stretch by design.
Can I reuse them??
What are they worth to buy new and are Toyota ones good enough??
TE72_Turbo
Re: Can Head Bolts Be Reused? Thu, 11 December 2003 07:31 Go to previous messageGo to next message
Toyota would recommend that you replace them Smile Rolling Eyes
I bought a new set for my 4AGTE from toyota for around $90 a set, then had my head gasket fail after 5 minutes of idling (copper gasket, no o-rings) so the head had to come back off. I replaced the gasket with a factory graphite one, and re-used the bolts, which may not have been the best option, but they have withstood 17-20psi regularly without any head gasket problems. I certainly wouldn't want to torque them down more than twice without replacement though.
gabe
Re: Can Head Bolts Be Reused? Thu, 11 December 2003 08:01 Go to previous messageGo to next message
Thanks for that mate....
TE72_Turbo wrote on Thu, 11 December 2003 15:31
....for around $90 a set, then had my head gasket fail after 5 minutes of idling (copper gasket, no o-rings) so the head had to....
By this do you mean that with a copper/metal head gasket, o-ringing is needed/essential/preffered??
Steve-AE86
Ademelaide, SA
Re: Can Head Bolts Be Reused? Thu, 11 December 2003 08:18 Go to previous messageGo to next message
yes. yes they can.
and toyota dont actually specify. not at my work, anyway...
we re-use headbolts all the time.
toyota headbolts aren't a torque-to-yeild design anyway, so you wont have a problem, just make sure you clean up the threads, with a wire brush, coat them with a little oil, and put some oil under the heads of the bolts, and on the washers, and away you go!!
TE72_Turbo
Re: Can Head Bolts Be Reused? Thu, 11 December 2003 11:58 Go to previous message
Not essential, but from my experience, definately preferred, even if the head has just had a surface grind to make sure its true.
Previous Topic:where is the rest of the head
Next Topic:O-ringed Blocked Assembly (7MGTE)
Current Time: Tue Oct 27 13:05:35 UTC 2026
Total time taken to generate the page: 0.030220985412598 seconds
