Toymods » Tech & Conversions » corolla 5k turbo lpg
dr650
adelaide
corolla 5k turbo lpg Thu, 11 December 2003 09:28 Go to next message
any idea how much cfm from 5k motor.
need to know as i want to turbo and lpg it and need to know cfm for mixer can any one help thanks
[Updated on: Thu, 11 December 2003 11:06]
Re: corolla 5k turbo lpg Thu, 11 December 2003 13:41 Go to previous messageGo to next message
easy to work out.
capacity of motor (in cubic feet), multiply by max rpm, divide by two, then multiply by boost ratio (ie by 2 if you have 1 bar boost, 3 for 2 bar boost)
dr650
adelaide
icon14.gif  Re: corolla 5k turbo lpg Tue, 16 December 2003 09:45 Go to previous messageGo to next message
Thanks for that
got motor fitted and runing but converter that i have is to small now looking for bigger one should fly when done.
mark
Re: corolla 5k turbo lpg Tue, 16 December 2003 11:40 Go to previous messageGo to next message
Ooooh, someone else is actually going to give the LPG a go ey Evil or Very Mad What sized turbo you using?
rolla69
icon7.gif  Re: corolla 5k turbo lpg Wed, 17 December 2003 01:04 Go to previous messageGo to next message
g'day. just noticed you have a 5k. I just dropped one into my ke10 and am interested in doing more work on it. what is yours in? do you have any ideas about the best way to turbo it?
dr650
adelaide
Re: corolla 5k turbo lpg Sun, 21 December 2003 10:11 Go to previous messageGo to next message
I am using a turbo of a ET pulsar (early) and have made my own manafold up. Have got it up and running but need bigger converter as i can only run around 3psi before runs out of gas. but goes a lot better just with that. used to run on avgas at about 14psi but to expensive to use every day .
bmak
Re: corolla 5k turbo lpg Sun, 21 December 2003 11:57 Go to previous messageGo to next message
An impco 200d will be perfect for your application.
I ran my 5k at 15psi with no problems.
dr650
adelaide
Re: corolla 5k turbo lpg Mon, 22 December 2003 10:45 Go to previous message
is that to mixer?? then what conferter did you use
me 125 mixer (to small i know) and model j impco
Previous Topic:ae86 wheel offset width
Next Topic:could someone tell me..(sprinter conversion)
Current Time: Wed Oct 14 09:51:20 UTC 2026
Total time taken to generate the page: 0.069453954696655 seconds
