Toymods » Tech & Conversions » Front suspension Conversion!! MkI Supra to MkIV - ideas?
FreaK
Canada
icon3.gif  Front suspension Conversion!! MkI Supra to MkIV - ideas? Fri, 12 December 2003 03:12 Go to next message
Hey all!
I know there are both big brains and big egos in this forum, so I'll pick one and pick on the other lol.
I run my MkI Celica Supra, MA47, 5ME (getting boosted) A40D trans, F303 LSD, 4 disks, and an attitude.
But it's not tunable enough, suspension wise!
I'm looking to upgrade the front suspension design to reflect the 20 years of engineering that have happened from inception to the present, and the best I can find is the MkIV Supra!
However, the problems represented here include such things as;
-single control arm/ strut vs. dual control arm
-engineering data availability on MA47 frame rail support of latteral loading if add upper control arm
-ride height engineering to maintain steering axis
-availability of MkIV engineering data on location (relative) and axis (plural) in order to properly graft the extra components....
you can see where this is going!
If I wanted to add *something* to the outer end of the MkI control arm, in order to upgrade the hub and brakes as well as spring and shock, got any better suggestions?
Current plan is this;
-source front-cut or replacement used parts, MkIV, balljoint with lower control arm, hub, rotor, caliper, balljoint with upper control arm
-locate and plan addition of upper control arm locations on the MkI frame
-graft lower balljoint section of MkIV lower arm to existing MkI lower arm (with strut rod)
-possible: make "slotted" or other adjustable upper mounts for primary camber settings
Anyone? Anyone? Bueller....?
Re: Front suspension Conversion!! MkI Supra to MkIV - ideas? Fri, 12 December 2003 03:30 Go to previous messageGo to next message
Upgrading your McPherson strut suspension to double wishbone suspension will require pretty much building a new car forward of the firewall. If all you want is more adjustability, this isn't the way to do it! McPherson strut suspension can be plenty adjustable with the right mods - just look at what the AE86 boys get up to, everything they do applies to you as well. Get some coilovers and an adjustable swaybar and you're most of the way there already!
FreaK
Canada
Re: Front suspension Conversion!! MkI Supra to MkIV - ideas? Fri, 12 December 2003 03:52 Go to previous messageGo to next message
thanks for da reply Norbie!
"adjustability" might be too soft a word. I need to be able to make this car dance.
I have a spring rate and right height I want, but camber is an issue now.
Urethane bushings helped but there is still too much force-related lateral motion in it.
The current swaybar is the 22mm one, and I have 3 different durometers of puck to go in steps from soft to hard
There is little room for slotting the current spring dia., and have you priced "pillowball" type upper mounts lately?
The shock is set valve, but still being hydraulic, I can easy change the action with oil weights/viscosity types.
I've never been one for "plug and play" solutions - I find they are far too average. this car is being built as almost a purpose-track-racer with plates, since I care not for comfort or convenience, just performance (wel, i put a stereo in lol)
I know the VW Golf III kits will fit both thread collars and inserts, providing I shorten the strut tube, but I was looking for ideas relating to adapting a more advanced suspension system into the car
ALSO - the other main point is to bring in a modern BP/offset with big brakes!!!!!
a set of stock MkIV supra wheels (17") with the STOCK TT rotors/calipers would be such a huge improvement!
If I just use "tricks" to make my current setup ... better ... then I still have the 4x114 BP, and a huge RWD set to the wheels! If I change the hub and move the bolt-face further out, I get the offset to current (+30-ish) as well as the brake bonus.
Then I only run "adapters" to get the rear wheels to fit...
Re: Front suspension Conversion!! MkI Supra to MkIV - ideas? Fri, 12 December 2003 04:48 Go to previous messageGo to next message
Keep it simple - coilovers with decent adjustable shockers and a camber kit. Norbie hit the nail on the head.
Talk to Allan about a brake upgrade - he is running a G series Hilux LSD with 291 mm ventilated rears. However, he is a cheap fucker, so he is being tres ghey and keeping the standard size front rotors and calipers till he has finished playing with the bargey MA70. We looked at some 320mm rotors from something non Toyota and thought they might work.
Funnily enough he is also running a 5ME (soon to be boosted) on BBQ gas.
ZZT231
melbourne.vic.au
Re: Front suspension Conversion!! MkI Supra to MkIV - ideas? Fri, 12 December 2003 22:07 Go to previous messageGo to next message
gianttomato wrote on Fri, 12 December 2003 15:48
... Funnily enough he is also running a 5ME (soon to be boosted) on BBQ gas.
Does that mean, next time when I see Allan's his MA45 powered 5M-TE. I need to bring sausages as well? Laughing
Keep me posted on what is going on as my MA61 needs some stiffing at the front Nod
Cheers.
Allan
Re: Front suspension Conversion!! MkI Supra to MkIV - ideas? Fri, 12 December 2003 23:58 Go to previous messageGo to next message
No gas dave just efi... unless it runs like a dog on the 5m-e ecu!
Back to the topic, IF YOU DARE HACK THAT MA47 I WILL GET ON A PLANE AND BASH YOU TO A PULP WITH THE REMOVED STRUT!
do it with an ra40 celica not a rare ma47! box in the lower control arm to stop that flexing and get adjustable strut tops!
Allan
FreaK
Canada
icon10.gif  Re: Front suspension Conversion!! MkI Supra to MkIV - ideas? Sat, 13 December 2003 00:37 Go to previous messageGo to next message
[quote title=Allan wrote on Fri, 12 December 2003 18:58
Allan
[/quote]
Laughing Laughing Laughing Laughing Laughing Cool
oh ye Gods I'm crying I'm laughing so hard....
Freak
FreaK
Canada
Re: Front suspension Conversion!! MkI Supra to MkIV - ideas? Sat, 13 December 2003 00:43 Go to previous messageGo to next message
OK - I think to *point* got lost.
I NEED TO UPGRADE WHEELBASE AND BRAKES TO SOMETHING I CAN FIT REAL WHEELS TO
This BP/offset stock is Kimpossible to get rims for, and 14x7 is nice, flat, good sidewal ratio, and IMPOSSIBLE TO BUY REAL TIRES FOR OVER HERE>
sry fer tha caps
the upgradde to a modern-er hub/rotor insited the overall upgrade idea, and I'm looking fro something I can fit pre-built adjustables into etc. Options are ... ZERO afaik for bolt-in, so the concept of welding a different end with BJ onto the lower strut came up adn I'm going from there....
I've spent 4 years managing to *not* hack up the '47... the most hacked it should get is to install a good safety cage and maybe change the spring perches in the rear for racing spring ones (for better selection)
BTW - I *can't* to this to any other Celica... I don't OWN any other Celicas.
Matter of fack; since I got robbed I don't seem to own much of anything at all. And I'm low-paid so I'm working on a make-it-yourself budjet all the time anyway.
Allan
Re: Front suspension Conversion!! MkI Supra to MkIV - ideas? Sat, 13 December 2003 02:30 Go to previous messageGo to next message
FreaK wrote on Sat, 13 December 2003 11:43
Go 5 stud, wide choice of cheap wheels available! and then a hi-lux diff (You should be able to get a decent price for your F series disc brake rear end) and run MA70 brakes front and rear and use common Ford wheels on the car (thats my plan anyway)
Allan
Re: Front suspension Conversion!! MkI Supra to MkIV - ideas? Sat, 13 December 2003 02:34 Go to previous message
Yeah, if you follow the MA61 5-stud/brake upgrade discussions happening on this forum you'll find that most of it applies to your MA47 as well. Big brakes and a wide choice of wheels, there's some more of your criteria taken care of!
Previous Topic:WHERE TO TAKE MY CAR 4 MECH WORK?
Next Topic:Installing tacho to ae92
Current Time: Wed Nov 18 19:26:03 UTC 2026
Total time taken to generate the page: 0.0065820217132568 seconds
